Pok-away and Carrara
Jamy
Hi,
I bought Pok-Away (in 2015), but I never used it.
I do not know how to use this thing in Carrara.
Yet, in the description, it says that it works with Carrara, but I do not see anything in the menu marked Pok pok or pok
Do you know how to use this thing in my favorite software?
Thank you
Salut,
j'ai acheté pok, mais je ne l'ai jamais utilisé.
Je ne sais pas comment utiliser ce truc dans Carrara.
Pourtant, dans le descriptif, il est dit que cela fonctionne avec Carrara, mais je ne vois rien dans le menu marqué Pok pok pok
Savez-vous comment utiliser ce truc dans mon logiciel préféré ?
Merci
Post edited by Jamy on
poke away not pok
and its under the parameters
I find soft select in the vertex room more preciseas it shrinks whole areas so if any parts exposed by clothing they look oddand withered
I use both Poke Away and Wendys method.
Thank you everybody :-)
in fact, I used it without knowing it.
But that does not work with all the clothes.
mebbe this tutt will help
Merci :-)
