What is this?
More importantly, how do I make it appear?
Thank you
  • KindredArtsKindredArts Posts: 1,337
    Thank you
    Its your view tools, click the little x in the top right hand corner of the box if you want it gone. Hit window/panes/view if you want it back.
  • bicc39bicc39 Posts: 589
    Thank you.
    But.....
    Two "view" sections, one lists perspective, front, side.
    The other lists Wire frame,smooth shaded etc.
    No "x" ????
    bicc39 said:
    Thank you.
    But.....
    No "x" ????
    The image you showed before had a small x in the corner? Are you talking about something different now?
    Problem solved, msunderstanding.
    Thought the "view" you meant was the two view panels in the camera window.
    The view you meant was Window./panel/view.
    Screen print not was not mine, captured from another site.
    Thank you so much for your help
