RDNA stuff at DAZ/purchased or not?
daveso
in The Commons
I used to buy quite a bit from RDNA ... SOME of it shows as purchased her since their move over, but not all of it.
Makes quite an unpleasant shopping experience as it is difficult to know if something was purchased or not. I downloaded all my past RDNA purchases, 474 items.
so its comparing each item ... I'm actually kind of tired of doing it, so avoid RDNA items ... plus I bought most of what I wanted at their store before.
Everything you purchased at RDNA that was moved over to DAZ should show as purchased here. You can use this one to check:
http://taosoft.dk/software/accm-daz/
Just click "Download history" and log in, then when the list shows up, check "Order #" under Search, type null in the search field, and search. It will list all your RDNA items then, and show the product pages in the right pane (Offline Mode must be unchecked). Using Arrow up/down keys to browse the list is the easiest.
Then there maybe an item nearly the same released at DAZ by the artist.
For example I nearly bought this item: https://www.daz3d.com/cookware
until I realized I had already bought this item: https://www.daz3d.com/contemporary-cookware
Also the way RDNA bundles were put together included items may not show up as purchased even though you bought the bundle.
The bundle problem is general; apart from Pro bundles, if a bundle shows as not purchased always check the individual items it contains before purchasing it, as you may already have all the items it contains.
I think ATIs plugin also have some handy features for checking these things.
Not everything. There are a couple of items by Surreality that was not added over at first, that has apppeared in the Daz store later, that has not been added to my account. (Surreal accents) I should probably contact support about it, just hasn't got around to it yet.
I'm getting tired of running through hoops. if i think i may have bought it, I'm passing. I havent seen much in the RDNA content that came over that I need anyway, just a few things that when its priced so low, hard to pass by.
What I meant was the other way around. Because the individual items weren't listed seperately in the bundle I could easily have bought the bundle and the individual items show up as not purchased. For example if I bought this: https://www.daz3d.com/lotusgown-bundle-for-v4-and-a4 I already have the LotusGown (https://www.daz3d.com/lotusgown-base-for-v4-and-a4) but it doesn't show as purchased. As good as ATI and Overdrawn's plugin is it can't help with this situation.
OK, yes I can see I have the same problem with some of my RDNA bundles. Some of them like the Victorian Innocence sets are a nightmare to figure out with bundles inside bundles and mega bundles and complete bundles overlapping each other etc.. I spent a lot of time checking the content lists for the bundles when I purchased them, so I believe I have them all, but still about half of them lists as not purchased in the store I can see. Guess you'll need to create a reference database if you want to be sure.
Aeon Soul retired their RDNA products rather than move them over to Daz.
If you have the orders/receipts to show that you did purchase the item, you might try contacting Aeon Soul at the DeviantArt account; I understand that they're more active on that account, and come to this forum only once ever 32nd blue moon, when someone tells them that there's something they really need to comment on.
Actually they had already retired them from RDNA before the merge was announced.
