can not open any file
hi all
since yesterday im not able to work with DAZ studio cause i cant open any item on it
every time i get could not open file error
here i attach a image:
any help is welcoming
thanks in advance
    You have imnstalled the Genesis Starter Essentials for the various generations of Genesis I presume
  • Richard HaseltineRichard Haseltine Posts: 108,927
    How did you install - Connect (from within Daz Studio) or Install Manager?
  • How did you install - Connect (from within Daz Studio) or Install Manager?
    thru DIM and the files are on the path DIM made on its instalation
    If you find the actual product, in the products tab of Smart Content, and right-click on it do you have an Install option or an Uninstall option?
  • If you find the actual product, in the products tab of Smart Content, and right-click on it do you have an Install option or an Uninstall option?
    uninstall option
    OK, that means it was at some point installed via Connect - and now that is the reference DS is using, but the files aren't there. try the uninstall option, then see if the files a) are still listed and b) load.
  • OK, that means it was at some point installed via Connect - and now that is the reference DS is using, but the files aren't there. try the uninstall option, then see if the files a) are still listed and b) load.
    i have used 'uninstall option' from products tab of smart content. i have unistalled genesis 8  starter essentials. it has changed to grey icon and appears the install option now
    That means that the Content Managment System isn't seeing the Install Manager install fro some reason. If you go to the Content Library and look under Daz Studio Formats>My Daz 3D Library>People>Genesis 3 Female do you se an icon for the figure, and does it load?
  • That means that the Content Managment System isn't seeing the Install Manager install fro some reason. If you go to the Content Library and look under Daz Studio Formats>My Daz 3D Library>People>Genesis 3 Female do you se an icon for the figure, and does it load?
    yep, i did it and it loaded from that directory.
    when i have done is once uninstalled from product tab of smart content, i clicked again in same place to reinstall. Then went to smart content and now seems that works. i think i have to do it for every package installed.
    seems it works in that way. Thanks a lot for all the help. I will let you know if once done all it works.
    Regards
    It does sound as if there may be an issue between DIM>CMS>Daz Studio, one thing to check is that you don't close DS and immediately start DIM as that can lead to the PostgreSQL database being shut down as DIM is isntalling (and so the content not being registered).
