Why is this so bright?
I just can't seem to work this out.  These are the settings I used (I made no alterations to any of the render settings, so they are all at the default values), and yet this is the image I got from the render.  Why does it look like there's a nearby nuclear blast?
image     image     image
  • FishtalesFishtales Posts: 6,218
    The shutter speed is set at 4 which will let too much light into the camera.
    Yes, take a closer look at the Shutter Speed parameter label — the (1/x) means the setting is for an "exposure" of 1/4 second, much too long unless the other camera-type parameters are also adjusted to compensate.
    Remember that these parameters work like the controls on a real manual camera. Shutter Speed is measured in fractions of a second. F/Stop values halve or double the simulated light entering the camera; going down it's 8, 11, 16, 22, 32 etc.; going up it's 8, 5.6, 4, 2.8, 2 etc. (the mathematical formula is a bit complicated). And Film ISO is the sensitivity of the simulated film; the standard "medium" value is 100, and it halves or doubles from there.
