Adding to Cart…
As someone who has always preferred to know how the engine works rather than just being told ideal values to plug into parameters, your tutorial was excellent! It helped so much to understand how the various sections of DAZ's Uber Shader interact with each other and how I could tweak skin settings based on lighting, desired look / feel, etc. I'd highly recommend it to anyone who wants to get the most out of their people renders using iRay.
The PDF doesn't explain what SSS direction setting you should use for skin. It's just this long technical explanation that doesn't help.
What should the SSS direction be for realistic looking skin?
edit: keep SSS direction at 0 for realistic looking skin
