ISO a specific non-specific hair
FWIWFWIW Posts: 320
edited April 2018 in The Commons
I'm looking for a hair here that has a morph for falling forward in front. Like... if the body were floating horizontally to the floor, the way the hair would fall straight down like that? Preferably for less than $14 - $15 dollars (I have store credit at the moment and I need it for a project.) Length and style do not matter so long as it falls right. I would prefer G8 but honestly, at this point, I will make do if I can find one that isn't blatantly toon.
Post edited by FWIW on
  • SimonJMSimonJM Posts: 6,076
    Have you tried using dForce on some hair?
  • FWIWFWIW Posts: 320
    no, the last I heard most of them fell apart
  • Phoenix1966Phoenix1966 Posts: 1,884
    There's Wild Wind Hair for G8F.
  • agent unawaresagent unawares Posts: 3,513
    You might try one of the rigged braids.
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    edited April 2018
    Well, there's always D-Formers, but those can only get you so far...
    Some of the ponytail orineted products, have separate 'bones/limbs' so you can rotate them forward, similar to an arm... this can work better than the weirdness that sometimes happen when you use a 'forward/back' and 'up/down' morph to approximate how hair should look when you bend over, etc...
    As for loose...
    Whitney Hair for G8F has four 'limbs' and some adjustments.  Here's how it looks when maxing out some sliders, and relaxing the parameters on the hair 'limbs' a bit more (say 90% instead of 80%)
    Free Spirit Hair for G3F doesn't have extra 'limbs' but using the wind and various forward/back/length/etc. morphs...
    It's a bit messy, but if you are going for that look...
    I'm sure others will chime in with some other options...
    800 x 731 - 108K
    800 x 858 - 155K
    Post edited by tj_1ca9500b on
    Very good ideas! Thanks :) I will definitely try these!
