Undead vs Fantasy Creature Creator Morphs ?
I already own the Fantasy Creature Creator Morphs:
https://www.daz3d.com/fantasy-creature-creator-hd-morph-pack-for-genesis-3-male
https://www.daz3d.com/fantasy-creature-creator-hd-morph-pack-for-genesis-3-female
How do the Undead Creature Creator morphs differ from the Fantasy morphs and is the difference sufficient to justify the additional purchase?
https://www.daz3d.com/undead-creature-creator-hd-morph-pack-for-genesis-3-male
https://www.daz3d.com/undead-creature-creator-hd-morph-pack-for-genesis-3-female
Thanks for  any insights,
Charlie
  • Joe WebbJoe Webb Posts: 837
    edited April 2018
    I have the male packs for both. I think they compliment each other. Pricey to have them split into two packages but then again a lot of work and detail went into them. It depends on what you think you'll do, obviously, but if you think you'll do a lot of undead images (halloween, horror, um..., etc.) then get both. If you only think you'll be doing fantasy with the very occasional undead, stick to figure like Mathius or Markus. These don't come with mats so you'll have to make your own. I use Skin Builder or Mathius.
    But if you can get them on sale, and have (or can get) mats, I'd recommend them highly. Great detail work. And I recently started using SimTenero Randomizer, and that has revolutionized my work with these sets.
    Edit - I attached a couple of portraits I did in the last hour. Samuel base, skin is Lord Alban (the RawArt albino guy) with a green cast, same for both. Sea Creature is fantasy morphs, vampire is undead morphs. Both applied with randomizer so it only took a few minutes of clicking to get a nice look. Glamed it up with some post work - mostly Nix filters and some Ron's Bokeh.
    They do look similiar around the mouth and nose, but that might be the Samuel morphs pushing through. Both have the same expression applied so that looks similiar. The cheek/jowel thing is similar so that is a worry. Supposedly the randomizer zero's out the morphs (if checked) so maybe something else is applied? Not pictured are the hands - the vampire hands have a distinct look, boney with long claws. The other looks relatively normal.
    596 x 965 - 500K
    596 x 965 - 509K
    Post edited by Joe Webb on
  • Charlie JudgeCharlie Judge Posts: 13,341
    Thanks. Since there were a couple of 'Newly Mad' items I wanted anywayI was looking at maybe picking them up as $10 off with a 'Newly Mad' item. At $3.58 each I went ahead and got them.
    Wow, that's a great price. I would have gotten them regardless.
