Iray not rendering correctly (re-installed graphics card drivers problem solved)
Security16Security16 Posts: 79
So I haven't used DAZ for a while and I decided to make a new scene but when I set the rendering up it does nothing and all I get is the grey and white squares as shown in the attached picture. I am hoping that I've just missed something simple as I've got no clue as to what is wrong and no error messages seem to come up either.
Post edited by Security16 on
  • barbultbarbult Posts: 26,354
    That is how it always looks at the beginning. Are you rendering with CPU or GPU? How long did you wait?
  • Richard HaseltineRichard Haseltine Posts: 108,590
    Does it work correctly if you turn Draw Dome on under Environment?
    That is where the renders would stop sadly. I uninstalled all my graphics drivers and did a fresh install of the drivers and it's all working now. I have an older nvidia card which apparently is being phased out so it looks like I may have to upgrade my pc soon
    I'm glad you got it working. Thanks for updating the thread title, too.
    I should have applied the second rule of 3d printing don't work if you can't brain :)
    Hopefully this may help someone else with a similar issue
