Problem to get cloths on V4 using another Character!
Alfhak712Alfhak712 Posts: 94
Then using a figure Alexa for Victoria 4
I got problem to use cloths that should fit to Victoria 4!
Then using the Alexa Body INJ the cloths does not fit properly
and very difficult to change the settings for the cloths so it works!'
Some of the cloths get inside the body etc!
I can only dress properly then not using BODY INJ
Even if I try to use the command "Fit to Victoria" it does not help!
I guess it has something to do with "Morphs" but I am only a newbie!
Any idea about this?
Alf
    Fit the outfit to the figure and then ensure it's selected. Right-click the outfit in the viewport and look at the bottom of the list for 'transfer active morphs'. That should fix any fitting issues. If there is still some minor pokethrough, you can select the scene tab, select the outfit and then in the scene options choose Edit -> Geometry -> Apply Smoothing modifier. That should help clear most of the problems up.
  • Alfhak712Alfhak712 Posts: 94
    Thanks for the help!
    The first tip did not work cause I could not find the "transfer active morphs" in the list in viewpoint then I selected the item!
    The second tip did the trick "Apply the Smoothing modifier"
    I had no idea about this but you make my day happy!
    Thanks!
    Alf
  • SzarkSzark Posts: 10,634
    It is actaully right click on the figure to find Transfer Active Morphs
