Tween Ryan Mats
Does anyone know which mats these are based on?
    I don't have it, but it says it is custom, so probably not genesis 3 male
    • Tween Ryan 7
      • Tween Ryan 7 Character Preset (.DUF)
      • Tween Ryan 7 Full Body Shape
      • Tween Ryan 7 Head Shape
      • Tween Ryan 7 Elf Ears
      • Tween Ryan 7 Custom UV Set
    • Tween Ryan 7 Materials:
  • PatroklosPatroklos Posts: 533
    Would like info if its out there thanks
    edited April 2018
    As FSMCDesigns says it's based on it's own UV, Tween Ryan. If you want to use it on G8M, then you have to the map transfer tool to change it to Base Male.
    Post edited by Male-M3dia on
    Definitely worth the money if you're using G3 UVs on G8
    Thank you for help
  • Noah LGPNoah LGP Posts: 2,617
    edited April 2018
    Map Transfer tool is FREE cheeky .
    The advantage is they become standard Genesis 3 textures, it could be useful for the future generations of figures.
    Post edited by Noah LGP on
  • AndySAndyS Posts: 1,449
    edited April 2018
    Map Trandfer Tool ?
    Don't I have to buy 3ds_Max for it first? Or is there a stand-alone Version available?
    Post edited by AndyS on
    It is free. It is also complex and time consuming.
  • LeanaLeana Posts: 13,516
    AndyS said:
    Map Trandfer Tool ?
    NoahLGP is talking about the "Map transfer" feature included in DS.
    Leana said:
    AndyS said:
    Map Transfer Tool ?
    Oh,
    how does it work?
    I see something like clone, shape, ... But skin maps, UVs ???
    edited April 2018
    1 set of textures to convert in 5min. versus to pay $15
    It's not as if you must convert the textures of all the figures. In that case, this product is very useful.
    The tutorial is very simple
    https://www.daz3d.com/forums/discussion/comment/3218821/
    Once you set the templates in Map Transfer, you can save the preset in order to avoid to set them manually the next time.
    Because I use NGS Anagenessis, I only set the diffuse maps for each templates (4 templates : face, torso, legs and arms).
    No need to convert the Mouth, Eyes, Eyelashes and Eyemoisture templates
