ZBrush to DAZ problem
Phantom Studios
in The Commons
Hi,
I am trying to create a Marvel character ( Captain Marvel ). I am using G3F and HSF Wraith Suit.
I sent just the suit over to ZBrush. I wanted to create the star on the chest of the suit. When I hit GoZ to send the star back to DAZ the star
will not parent in place after I select transfer utility G3F to the star. It doesn't align the star properly. It aligns slightly off the chest of the suit.
When I go to move the figure the star does not move with the suit. I could use suggestions. Thanks
Transfer to the suit instead of G3F? :)
Also, send the set that is NOT working to Zbrush including deformations, make the correction in ZBrush, then send BACK to DAZ and when you do, instead of choosing to make it a morph, update the geometry instead. It should fix the issue.... I hope.
I fixed it. I think it was a resolution problem and transfering the suit to the star worked under transfer utility.
Thank you!
Someone guide me on this process...I need to learn to use zbrush with daz studio. Can someone point me to some good tutorials? I want to make a facial morph as my first project.
If my tutorial is still around, yes. I need to modify it with new info and pics, though. I will see about that tonight when I get home and leave a link here. :)
Thank you! I'm trying to find youtube videos that will help me out, but something specific from you would be wonderful!
Ack... that tutorial needs some MAJOR work and the pic links are ruined. I will need to update it over the weekend.
