S.H.A.D.O.ws from the past - [WIP]
2»
  • SixDsSixDs Posts: 2,384
    Yes. And no. I was unable to get the .obj to load as a morph using Morphloader Pro in DAZ Studio, and not for want of trying. I could never figure out why it wouldn't work. However, I did finally succeed, but not using DAZ Studio. As I recall (it was a long while ago), I ended up successfully loading it in Poser, and, once I did that, I could save it as a .cr2 file. I then could load it into DAZ Studio. So, if you have a version of Poser, it can be done, otherwise not to my knowledge, sorry.
    800 x 800 - 398K
  • Richard HaseltineRichard Haseltine Posts: 109,474
    I have had success, a time or two in the past, using Morph Loader Advanced rather than Pro. That probably means there was a combination of settings in Pro that would have worked, but it was the end result that mattered.
  • lukon100lukon100 Posts: 849
    Yay for Ayshea!
    This may be of some interest for those wanting to use the Jo Etzold moonbase uniform for V4 on G3F figures - a way to get the textures looking more realistic: https://www.deviantart.com/luqu/art/MoonBase-Uniform-DS-Texturing-V1-801338074
    826 x 825 - 332K
  • KeryaKerya Posts: 10,943
    On a related note, has anyone managed to get the various sculpted head morphs from Steve Kitt (that are on ShareCG) to work via morph loader pro?  I've been trying to get the Ayshea Brough morph from ShareCG to take using Victoria 4.2 as the target figure, but it gives me an error message:
    - No deltas for morph, skipping mode
    It says that it has created the morph successfully, but (as far as I can see/search) no new morph appears has appeared in my parameters or shaping list...
    Just for fun, I tried importing Ayshea's head morph.obj into Daz, which just makes an invisible cube with no features/nodes.  Importing or bridging to Hexagon doesn't work (head shape never appears in Hexagon).
    Any suggestions?
    Did you follow the instructions in the Feedback section?
    "Hi Jeremy,You load up V4 in DAZ,then in the scene tab,open up the V4 menu till you get to the head,select it,then use Morph loader to bring the new head on board."
    Did you select the head to see whether the morph shows up there?
