JCM Hook Up Question
in The Commons
Does anyone know if it's possible to have a JCM that depends on two or more conditions. For example, a JCM that will activate when the arm is up AND back and not only when it's up OR back. Is that possible?
Cheers,
Martha E.
That is a multi-rotational JCM and it is, indeed, possible. I do not know how to do it though :D But you can put a TON of conditions on a morph. If you're searching the forums, wiki or YouTube, multirotational is what you're looking for.
Thank you very much, ChangelingChick. Is good to know it's possible. I'll try to find more info. Thanks for the tip.
Cheers,
Martha E.
I can't seem to find any info about multirotational JCM. Do you remember where did you see it? Thanks again.
I don't I'm afraid :/ Do you use Property Heirarchy or ERC freezes?
I'm using the Property Heirarchy to hook up the JCM.
You can drag more than one thing onto a control as I recall, and there are 2 stages for controllers I think (1 to add, 1 to multiply maybe?). I would experiment a bit with those, just remember to have the morphs saved before you hook in the JCMs. Sorry I can't help more :(
Thank you very much ChagelingChick. Yo have been very helpful already. I really appreciate it.
