dforce - sweet anime outfit
https://www.daz3d.com/dforce-sweet-anime-outfit-for-genesis-8-female-s
Is it possible to contact Anna Benjamin Nikisatez
I am having issues with the lighting in DAZ.
I use Arrah lighting but the figure is dark and the parasol way too light and looks odd.
Any ideas how I can get the lighting right on this figure and outfit.
I have tried applying the low res and using a spotlight. neither work.
Thanks for any help.
Regards
Carolann
  • another picture
    2499 x 3235 - 2M
  • nicsttnicstt Posts: 11,715
    edited April 2018
    Is this Iray or 3delight?
    Edit:
    I loaded PixCharu, Anime Hair and the Outfit. I applied a pose (tweaked the hair and hand holder the umberella only) - so no dforce applied.
    I positioned the cameral angle, and used my default lighting setup. It uses a low-level HRDI, and two or thee lights besides (usually two as I turn the 3rd off). I used DOF on the camera.
    It looks in that image, presuming you are using IRAY, that there is little light on the character, with a considerable amount of light behind the umberella.
    It is hard to say as we have so little information.
    Edit
    Second image; tweaks on lighting, and turned on the visibility for the HDRI as it is suitable (I suppose) for an anime render.
    Rule of Thumb - issues for me at least are lighting related.
    1273 x 1800 - 2M
    1273 x 1800 - 2M
    Post edited by nicstt on
