Need help achieving effect - Being of light
aqarazaaqaraza Posts: 0
Greetings! I am a novice, so please feel free to let me know if this belongs elsewhere.
I am shopping around for a shader, skin, or other effect that will cause my characters to appear as if they are traced of light, electricity, data, translucent energy, etc. An example of the type of effect I am trying to achieve:
http://24.media.tumblr.com/tumblr_m07jfvX4KW1r2an97o1_500.jpg
(Or, see attachment.)
Please let me know of anything you know of that gets anywhere even remotely close to this kind of effect. :) Thanks!
- aqaraza
  • Zev0Zev0 Posts: 7,123
    edited June 2012
    It can easily be done. However to get that streaky light lines requires post work. I will make you this shader when I have time. Just need to remember where I put my Uv templates. The secret is to paint a "light" dot on the vertices of the uv map. That makes sure the dots follow the contour of the figure. (add some in-between for diversity). Then all you do is make a transparency map that isolates the dots, turn up the ambience of the diffuse texture and ur done.:) Is this for a male or female?
    Post edited by Zev0 on
  • aqarazaaqaraza Posts: 0
    Well, when I said novice, I meant novice -- I am actually evaluating tools and deciding which to learn (and delve into) based on the outcome of this task. So, I don't even have my model yet.
    I did find these two modules as well, which get pretty darn close to kind of thing I am looking for...
    http://www.daz3d.com/shop/pwghost/
    http://www.daz3d.com/shop/pweffect/
    - aqaraza
  • JohnDelaquioxJohnDelaquiox Posts: 1,197
    Studio 4 Pro actually can't be beat at the moment. Its still free I think and genesis is an amazing products and those shaders have Xray which gives you a nice almost vr effect
  • EximorphEximorph Posts: 35
    The picture you posted looks to me like an image projected onto wires, so I made a very simple dynamic hair in Carrara 8 for a screen. Then I added a gel image to a spotlight as a projector.
    I made the gel image by adding a surface replicator containing a light bulb to V4. The bulbs had 0% intensity and excluded all objects, so they didn't actually light anything. By adding lens flare you can get all sorts of glowy special effects.
    640 x 640 - 228K
    800 x 800 - 345K
  • ReDaveReDave Posts: 815
    Wow that looks great Eximorph!
    The OP image appears to be based on intersection of the thin tubes with the figure mesh, placing a bright spot at intersection and then fading the further away the tubes move from intersection. I know how to do that in say POV Ray, but no real idea of how to handle it in DS.
