Can Daz/Iray render any of the view choices (wireframe or bounding box?)
That question above. Can I get iray to render the viewport in any of its modes? Can I render the bounding box view?
I've been using screen-capture in a pinch, but just curious, if there's a another/better way.
  • barbultbarbult Posts: 26,325
    edited March 2018
    I believe that you can render wireframe if you select Basic OpenGL for your render engine in the Editor tab of Render Settings. The attached render used the Hidden Line draw style and was rendered with Basic Open GL.
    1236 x 2000 - 2M
    Post edited by barbult on
  • MattymanxMattymanx Posts: 6,997
    The best method I have found to do this, is to use the UV maps as textures and render it.
  • Griffin AvidGriffin Avid Posts: 3,822
    Hey Matty, how the heck do you do that?!
  • FSMCDesignsFSMCDesigns Posts: 12,845
    take the texture template and apply it instead of the diffuse and then render
