Another where did this item come from...
Geminii23
in The Commons
Anyone know where this item is? Really wish the PAs and DAZ would list every product in the promos. Would also lead to more sales for them, right?
where's the promo from. More info helps.
Sorry it is Ollie 8 promo image
The collar looke similar to the one in this set with a slightly different shape. I would bet it is the same modeller who made this one.
I would love to find a decent tall collar like that to use for a Dr. Stange outfit and also for a Spawn character.
Yeah, something along those lines would be perfect for Dr, Strange. Uzilite did a Dr. Strange-ish cape years ago. ANd they had another one that was very much styled after Dr. Strange for either Michael 1, 2 or 3. I can't recall where it was sold or if it was a freebie.
That one actually might work if it autofits nicely for G1/2/3
Looks like it came from this set, not sure if there's been a version for Genesis 3 or males in this manner: https://www.daz3d.com/dark-princess-for-genesis-2-female-s
https://www.daz3d.com/lotus-maiden-outfit-for-genesis-3-female-s
Maybe this? I bought it when I got the Mei Lin 7 Pro Bundle
Oh yeah, I think that's it. I thought it looked like Lotus Maiden, but the collar for Ollie looks just like Dark Princess.
Lotus Maiden came to my mind first too but doesn't look quiet the same :) There's been one more set (Synful Witch) on Genesis 2 I think that had an interesting collar as well.
I think you're right and at least I feel a little better knowing it was the same team behind the outfit.
I have the outfit, so which figure would you like to see it on?
Yup. I think that is definitely the one. Added to my wishlist. Thanks guys!
I generally prefer G2M, so if you are able to autofit and see how that works I would appreciate it. Also, it is hard to tell from the images, but does it come with a cloak as well or is it just the high collar suit and the cloak they are using is from somewhere else?
I'll try the suit on G2M as soon as I fiish a test render. The cape is not included with the set, but is a freebie over at Renderosity. You do need the suit to be able to use the free cape.
These are very quick and dirty. I just autofit straight to G2M, when perhaps going from M4 to Genesis, saving and then fitting to G2 might give better results. The cape was very fiddly and the points broken. The collar points looked broken in some poses and not in others. And, since Uzilite tends to style clothes for narrow people (the suit comes with mat poses to hide parts of M4's body), I had to hide the same ones on G2 to avoid poke-thru.
Someone more adept at fitting might have much better results than I did.
Thanks for sharing that. I downloaded the Cape. Most capes usually just need to be parented cause they autofit like crap. I will definitely experiment with this.
