is there a wet skin avaliable for G3 in 3Delight?
Toobis
in The Commons
Can't find anything at that would help with wet skin for G3 characters, its all Iray and not 3Delight. Anyone know where to find such a product? thanks.
Using simple shaders nothing fancy for G3F how can it be done please. Try and make it simple please I just need a basic wet look.
If 3Digital means 3Delight I might be able to give you some tips, just tell me what kind of lighting you plan to use in your scene (DS standard lights, AoA lights, UberEnvironment2 , IBL-Master or something else). Also I need to know what shader you use for the skin(DS default ,Omnifreaker UberSurface, AoA SSS or other). If you don't know, go to the surface tab with the character selected and look in the upper left corner to find out the name of the shader. I'll be back in a couple of hours and can try to help if you haven't solved it by then;)
Meant 3Delight sorry lol. Just DS standard lights and for the character it just says 'multiple' for shader.
You actually had it right in your first thread - with which the new one has been merged. Please don't bump or multi-post.
eh? had what right? oh ok gotttit sorry.
Ok, if you select one of the skin surfaces in the surface tab, like hip, you should see the name of the shader being used.
I don't know if this is what you're looking for, but I used the G3F base figure out of the box and tweaked the skin she loads with. Used a couple of DS standard spots + AoA advanced ambient light.
This is the AoA SSS shader, you could also try the UberSurface shader by Omnifreaker, it renders faster and is IMO easier to work with.
K nevermind. I don't have any of these fancy subshader things you seem to need to do this I thought it'd be simpler. Thanks anyway :)
Awesome shader! Thanks Sven Dullah !
Had forgotten all about this:)) You're very welcome!
