How to export Skin to GIMP
PhiloppPhilopp Posts: 294
Hello dear all,
I saw a tutorial about how to use the PS bridge to work skin on PS, is there a possibility to export skins so that they can be elaborated on GIMP?
Thank you very much for your answers.
Greetings
Ting
    Hello Ting
    Yes, you can load texture files in Gimp. Load your figure in DAZ Studio, select it in the Scene pane, then go to the Surfaces pane as shown below. Select the texture that you want to work on, and click on the Diffuse channel, and use the Browse button to take you to the folder that holds all of the image files.
    You can load these directly into Gimp fom there, but just remember to save the file under a different name, or you will overwrite the original. Just load your new texture in the Surfaces pane in place of the original one. Does that help?
    946 x 682 - 386K
  • PhiloppPhilopp Posts: 294
    Thank you very much for the speedy answer. It's great!
