Adding to Cart…
From what I see this would seem to answer the prayers of a lot of people who have wished to have head and body morphs separate on a figure, so that alone is going to gain you a lot of love! Being able to add morphs with a form of assymetry is going to please a lot of people, too - adding just a little tweak of a morph to one side of a head/face will enable 'imperfections' to be simply added.
For the images, in the original post teh top two grab me more, the one on the right' version shown later is better than the original for the reasons others have posted. Back to the OP and I am less sure bout the 3rd and 4th despite them showing what can be done - just something about the lighting doesn't engage my attention.
As for the producty itself - just let me know when, and I'll buiy!!!
Thank you, your comments are very valuable.
Hey - I resemble that remark! I ended up taking a completely different approach than I was originally. The issues are solved, but I'm still unsure about whether or not I will be releasing them as a product, or keeping it for use in-house. Going on what @CGI3DM has posted, the 2 scripts operate in a very different way.
My scripts are focused on, and contain additional functionality to allow for, sculpting directly in DS. While the result of this sculpting can obviously be used to create morphs (and helps the user to do so), it does not attempt to adapt/create all of the JCMs, weightmaps, etc. needed to make a complete, fully-functional figure ready for use in DS.
I look forward to seeing what @CGI3DM's script can do!
- Greg
Looks very interesting. Is there a name planned for it so I can keep an eye out for it in the store?
X-Morphs
4.8????
Although it works, you will have certain details that you will not have. Nothing really important.
I also use 4.10.0.123 & 4.10.0.123 Public Beta
Looks like a fantastic product. Will it work on HD morphs?
No, only SD. :(
Does it take care of the JCMs as well? I am wondering how FBMs would work on a fused figure?
On a similar line of thought, I am wondering if this could be used to apply FBMs partially (i.e. as PBMs)? EDIT: It seems it does only at the pre-defined regions. Also a suggestion that the torso could have been split into upper and lower halves to make the likes of Popeye/Bluto.
Does it support multiple FBMs simultaneously (one for each body part)? Is it possible to apply different FBMs iteratively (like multi-pass)?
Shame; I returned an HD morph as I cant choose which areas it affects; either all or nothing... I chose nothing and raised a ticket.
Shame about not crossing generations, still would be an instabuy for me as it would allow me to do some fun combos. There's certainly nothing else like it that comes to mind! :)
I am curious about this too.
Select a only morph, anybody (PBM, FBM), and you can extract the part that interests you with Easy (head, torso, Arms, Legs), by material, Bones, Cutting Plane, Weight Map, and save the Morph.
Now select another morph or the same, and choose another method, and save.
Finally you can mix the 2 or more morphs that you have already created.
Cutting Plane: through a plane you can move and rotate (vertical, horizontal,0-360°), which allows you to practically cut the Morph where you want.
Or you also have the option of the weight Map.
No, in this version.
Yes, hopefully and in the future there is a way to do it.
I understood exactly what this does from the images in the first post.
As far as which is better, honestly, the left one grabs my attention more but the right one is the one you should use because there is no ambigouity about what does and does not come with the product.
Can you split morphs on different sides of the face by area: ie right side of mouth only or right side of nose or right jaw, etc... in in small amounts for assymetry? Is everything so exaggerated or can you do subtle morphs?
If possible, it would be in two steps or more steps depending on what you would like.
For example, you have a head morph called vicky, you select the area you want by vertex, face, edge or weight map, save for selected and another for not selected.
You would then have 2 morphs VickySelected, VickyNoSelected, each with its own adjustment dial.
Although in this case use, two different morphs, can be the same. Emaciated left FBMBodybuilderSize Right. I suppose that if the same morph had been used, with percentages of 100% and 98% I would have given the asymmetry that you are looking for.
Basically the script only divides the morph, in the part you want, you decide the strength of the morph using the dial.
The only detail is that there must always be a morph, you can not do it on the base figure.
I said what LOL? How did that get in Spanish? I got an A in high school Spanish but remember very little of it LOL...
Jajaja
This product looks awesome! I think the promo is very self explantory as to what to expect from the product. You have buyer here. I hope Daz approves your product.
Thank you.
Yes, just wait.
This is what has me very interested. I have had to pass on products because the vendor decided they wanted to stick with their creative vision and only release a full body morph. If this will allow me to be able to use either the head or body and not both at the same time, I am sold.
Is there a way to control the smoothing distance/radius at the joints? I remember this was a feedback given to the zone smoother scripts, but I guess, we are still waiting for a solution.
I am one of those happy people! This is going to go in my cart then into my library as soon as it hits the store!
Yes, you can control the area and length of the smothing, by default they are 10 cm, with respect to the border between the morphs.
Being able to split FBM character morphs will be a godsend. A pity that it can't go across generations, but that probably was never really in the cards. I am interested in the possibility of transfering only one arm or one leg rather than both at once. Your control panel shot doesn't show that function, but I am assuming that it is in one of the additional tabs?
Yes, in Bones
The product looks great. I hope you will have a video to show what you mean in the above for those of us who are not as savvy/knowledgeable. It sounds a little complicated to me, but a video or some form of step by step instruction would likely clear it up.
