Geometry did not match, failed to create morph, i use 3d max edit obj ,and to daz morph loader pro
Warning: Geometry did not match, failed to create morph
My question may be special, sorry.
1,in daz export obj,to 3d max edit
2,after modification use daz morph loader pro to same prop,but show "Warning: Geometry did not match, failed to create morph"
  • Richard HaseltineRichard Haseltine Posts: 111,503
    Make sure that the figure was set to base reolution, and that it was the only visible item in the scene (with Genesis 8 make sure the eeylash, and brow if present, figures are hidden as well as any clothing, hair, or props).
