Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Here is an image I did using your grass and the free replicator script. Thank you.
I also tried out your grass in Carrara using the surface replicator.. thanks
used on this image..
Thanks - great product.
I used it in one of my entries to this months freebie contest: As Green as a Dryad's Grove
I didn't use any scattering script or product, just created and duplicated node instances to make patches of grass I could place manually.
It took me awhile to get back to this, because my computer was in the shop (dead MB
), but now It is back. The new ground with UV mapping is working great. I was able to apply a ground shader just fine. Thank you for the update!!!!
Thanks for this!
Ultrascatter makes this what is made easily by default from of any serious 3D program... besides DS where you have to buy it.
_And how about this_?? _iray is not an option in render engine
You are using Daz Studio 4.6. I believe that is too old to render with Iray. The latest released version of Daz Studio is 4.10.0.123. The latest Beta is 4.11.0.236. Both of those have Iray support.
_Alright then ,Thanks Not sure which version iRay started with _, will continue to use 4.6 then_
_ Daz Studio 4.8 _
