BACKCHAT! - Do You Have the Time - #39
Stezza
My ramblings to get you in the mood and to take any questions....
The Challenge Details will be posted by Monday hopefully.. after I nut it all out.. in the meantime............
Time travel — moving between different points in time — has been a popular topic for science fiction for decades. Franchises ranging from "Doctor Who" to "Star Trek" to "Back to the Future" have seen humans get in a vehicle of some sort and arrive in the past or future, ready to take on new adventures.
The reality, however, is more muddled. Not all scientists believe that time travel is possible. Some even say that an attempt would be fatal to any human who chooses to undertake it.
What is time? While most people think of time as a constant, physicist Albert Einstein showed that time is an illusion; it is relative — it can vary for different observers depending on your speed through space. To Einstein, time is the "fourth dimension." Space is described as a three-dimensional arena, which provides a traveler with coordinates — such as length, width and height —showing location. Time provides another coordinate — direction — although conventionally, it only moves forward.
Time machines
It is generally understood that traveling forward or back in time would require a device — a time machine — to take you there. Time machine research often involves bending space-time so far that time lines turn back on themselves to form a loop, technically known as a "closed time-like curve."
Grandfather paradox
Besides the physics problems, time travel may also come with some unique situations. A classic example is the grandfather paradox, in which a time traveler goes back and kills his parents or his grandfather — the major plot line in the "Terminator" movies — or otherwise interferes in their relationship — think "Back to the Future" — so that he is never born or his life is forever altered.
If that were to happen, some physicists say, you would be not be born in one parallel universe but still born in another. Others say that the photons that make up light prefer self-consistency in timelines, which would interfere with your evil, suicidal plan.
Some scientists disagree with the options mentioned above and say time travel is impossible no matter what your method.
Obviously they haven't heard of Carrara..
You are in charge of TIME
If you could go anywhere in time wether it is the recent time or way back in the caveman days or the unknown future your mission is to render it...
Render your time scene, model your time machine if you like or download a freebie one or you may even already have one in your Runtime..
Animate your time scene if you wish... I'd love to see a timepiece going backwards.. Think outside the dimensions... let yourself loose and render away.
One-way travel to the future: The traveler leaves home, but the people he or she left behind might age or be dead by the time the traveler returns. Examples: "Interstellar" (2014), "Ikarie XB-1" (1963)
Time travel by moving through higher dimensions: In "Interstellar" (2014), there are "tesseracts" available in which astronauts can travel because the vessel represents time as a dimension of space. A similar concept is expressed in Madeleine L'Engle's "A Wrinkle In Time" (2018, based on the book series that started in 1963), where time is folded by means of a tesseract. The book, however, uses supernatural beings to make the travel possible.
Travelling the space-time vortex: The famous "Doctor Who" (1963-present) TARDIS ("Time And Relative Dimension In Space") uses an extra-dimensional vortex to go through time, while the travelers inside feel time passing normally.
Instantaneous time jumping: Examples include "The Girl Who Leapt Through Time" (2006), the DeLorean from "Back To The Future" (1985), and the Mr. Peabody's WABAC machine from "The Rocky and Bullwinkle Show" (1959-64).
Time travelling while standing still: Both the "Time Machine" (1895 book) and Hermione Granger's Time-Turner from "Harry Potter" keep the traveler still while they move through time.
Slow time travel: In "Primer" (2004), a traveler stays in a box while time traveling. For each minute they want to go back in time, they need to stay in the box for a minute. If they want to go back a day in time, they have to stay there for 24 hours.
Traveling faster than light: In "Superman: The Movie" (1979), Superman flies faster than light to go back in time and rescue Lois Lane before she is killed. The concept was also used in the 1980 novel "Timescape" by Gregory Benford, in which the protagonist sends (hypothetical) faster-than-light tachyon particles back to Earth in 1962 to warn of disaster. In several "Star Trek" episodes and movies, the Enterprise travels through time by going faster than light. In the comic book and TV series "The Flash," the super-speedster uses a cosmic treadmill to travel through time.
(extracts from space.com )
so you have questions.. I know I've already seen them.... in the future...
When Did Time Travel Come From?
Dr Who
BTTF
The Time Tunnel
Quantum Leap
Top Ten
Dr Who stuff
http://vanishingpoint.biz/freestuff.asp?StartNo=855&ClassificationID=8
Time Machine
http://www.sharecg.com/v/85766/browse/5/3D-Model/The-Time-Machine
Hi,
don't forget to use the good font ! ;-)
https://www.dafont.com/fr/back-to-the-future.font
Classic Trek time travel:
OH.... I hope I can do this. As my interests are in prehistory... I have a couples of things in mind. Can it be a scene of what the traveller's new environment is like after arrival and assimilation and his/her place in it? Migh need a couple of scenes merged if you want to see the machine as well, or the portal, and a bit of narrative in a balloon or under the render as I am not an animator.
Sounds like fun!
Galaxy Quest - go back in time just far enough to correct one mistake
Escape from the Planet of the Apes - futuristic apes go back in time to 1972
Anybody remember "Voyagers!", and the Omni?
“If the Omni is red, it means history is wrong. Our job is to get everything back on track.” – Voyager Phineas Bogg
I missed that series somehow. The videos look fun.
This soon to be released product from @TangoAlpha could be converted into a Time Traversing Machine
which leads me to say that our PA sponsor for the challenge will be
TangoAlpha
I hope you can as well Silene.... get them eyes up to scratch and do your prehistory render for us.. and as always have fun doing it..
I don't think Voyagers! showed here in Oz.. I've never heard of it before. But the Omni would be an awesome model to do
like Voyagers! I don't recall seeing Galaxy Quest either on Oz TV...
but all the Planet of The Apes movies have been ..
I did this one of the Hivewire gorilla when it was released..
steanpunk time travel?
The Final Countdown (movie) https://en.wikipedia.org/wiki/The_Final_Countdown_(film)
http://www.imdb.com/title/tt0080736/
The Philadelphia Experiment https://en.wikipedia.org/wiki/The_Philadelphia_Experiment_(film)
http://www.imdb.com/title/tt0087910/
http://www.imdb.com/title/tt2039399/plotsummary?ref_=tt_ov_pl
Unidentified Flying Oddball https://en.wikipedia.org/wiki/Unidentified_Flying_Oddball
http://www.imdb.com/title/tt0080062/
Terra Nova https://en.wikipedia.org/wiki/Terra_Nova_(TV_series)
http://www.imdb.com/title/tt1641349/
Primeval https://en.wikipedia.org/wiki/Primeval
http://www.imdb.com/title/tt0808096/
Prehistoric Park https://en.wikipedia.org/wiki/Prehistoric_Park
http://www.imdb.com/title/tt0760139/
"I'll be back" The Terminator series
https://en.wikipedia.org/wiki/Terminator_(franchise)
Army of Darkness https://en.wikipedia.org/wiki/Army_of_Darkness
http://www.imdb.com/title/tt0106308/?ref_=ttls_li_tt
The crooner, Bing Crosby in King Arthur's Court.
http://www.imdb.com/title/tt0041259/
World Without End
- quote from the IMDB description - "Astronauts returning from a voyage to Mars are caught in a time warp and are propelled into a post-Apocalyptic Earth populated by mutants."
http://www.imdb.com/title/tt0049964/
Idiocracy
"Private Joe Bauers, the definition of "average American", is selected by the Pentagon to be the guinea pig for a top-secret hibernation program. Forgotten, he awakes five centuries in the future. He discovers a society so incredibly dumbed down that he's easily the most intelligent person alive."
http://www.imdb.com/title/tt0387808/?ref_=fn_al_tt_1
Seems like the challenge will be to do the Time Warp.
Jump to the left and step to the right.
Almost as if Mr. Estaire and Ms. Powell did the Uptown Funk.
Bill and Ted's excellent adventure
my fav
I should have saved this for this Challenge. :)
Cover art was Carrara. Text and grunge PSE 2018.
Bill: So-cratz - "The only true wisdom consists in knowing that you know nothing".
Ted: That's us, dude.
Looking forward to seeing one of Wendy's most excellent animations
A most excellent theme.
here's a crappy model of the old time machine.. if it's useful to anyone, anytime :)
https://www.dropbox.com/s/1pn4wock48ykin2/The 1962 Machine.car?dl=0
the mussels from brussels in ...
