Lost of volume when changing the poses, script DzMorphDeltas
CGI3DMCGI3DM Posts: 279
I made a script to import morphs, with DzMorphDeltas
//example problem, copy deltasoNode = Scene.getPrimarySelection();oObject = oNode.getObject();oModifier = oObject.findModifier( "FBMPearFigure" )oMorphDeltas = oModifier.getDeltas ();oNewModifier = new DzMorph( oMorphDeltas );oNewModifier.setLabel( "New_FBMPearFigure" );oNewModifier.setName( "New_FBMPearFigure" );oObject.addModifier( oNewModifier );
Make the shape correctly, Testing with "Pear Figure". the new shape "New_FBMPearFigure" it loses volume for certain poses, for example, when moving the Side-Side leg 70,120.
Import with morphloader, work fine
it will be WeightMap ?. Links, ERC? what will I be missing?
Post edited by CGI3DM on
  • Richard HaseltineRichard Haseltine Posts: 109,456
    Have you checked to see if there are other morphs linked to both Pear Figure and the bends? You can see a list of Sub Components by clicking the gear icon on the morph's slider and selecting Parameter settings.
  • CGI3DMCGI3DM Posts: 279
    If I save the figure in a file, and reload it works fine.
    The problem seems to be with the creation of Dzmorph, since if I overwrite an existing morph it also works, for example created from a D-Form.
    oNode = Scene.getPrimarySelection();oObject = oNode.getObject();oModifier = oObject.findModifier( "FBMPearFigure" )oMorphDeltas = oModifier.getDeltas ();oModifierMD = oObject.findModifier( "MorphCreateofDForm" )//any morph, Spawn D-FormeroModifierMD.setDeltas( oMorphDeltas ); //It works well.
