GenX2 Definitions not found.
Blackbirdx61Blackbirdx61 Posts: 300
When I run GenX2 the source tab is greyed out; so I can't use that, nor can drop and drag anything over to the Morph Area.
No Source Figrure Definitions Found
No Target figure Definitions Found
From what I've seen online researching this problem GenX is not finding my Genesis and V4/M4 series charactors even though it was installed via IM and my IM paths have not changed in years. I tried moving the ini to a public folder but that did not work.
The Ini currently lives here, but I cant be sure based on what I've seen that this is the correct adress.
C:\Users\BB\AppData\Roaming\DAZ 3D\Studio4\GenX2
I currently Run DAZ 4.7; its old but the DAZ lit assures me that the plug in should work for any DAZ version 4.5 and Higher and I'm pretty well sure there is a pathing issue at the root of this problem.
The GenX Ini is reproduced below,  all the folder data is blank, I typed the first three rows in by hand trying to show the plug in where Genesis lives on my computer but to no luck. While I opened a Ticket with the DAZ help desk; my experiance has taught me that any help I might get concerning DAZ will come form the Forum Community.
TY in Advance. BB.
GenX2.ini
[layout]
col0=80
col1=40
col2=50
col3=80
div1=false
div2=false
tab=3
[options]
min=-10
max=10
res=50
nailbed=false
useclone=false
compress=true
transform=true
group=true
show=false
useout=false
targetid=false
sourceid=false
morph=true
scale=false
eye=false
shape=true
fix=true
custom=false
exclude=false
zero=false
match=1
cond=0
replace=1
search=0
trans=5
figure=
[path]
0=C:/Users/BB/Documents/Daz 3D/Studio/my library
1=C:/Users/BB/Documents/Daz 3D/Studio4/content/ ... Mostly set and Toon presets I've cobbled together here; no purchased content.
2=C:/Users/BB/Documents/Daz 3D/Studio/my IM library
[list]
control=1
hidden=false
empty=false
joint=true
pose=true
connect=
[folder]
0=C:\Users\BB\Documents\Daz 3D\Studio\my library\data\DAZ 3D\Genesis (by Hand)
2=C:\Users\BB\Documents\Daz 3D\Studio\my library\data\DAZ 3D\Genesis 3 (by Hand)
1=C:\Users\BB\Documents\Daz 3D\Studio\my library\data\DAZ 3D\Genesis 2 (by Hand)
2=
3=
4=
5=
6=
7=
Post edited by Blackbirdx61 on
  • Noah LGPNoah LGP Posts: 2,617
    edited March 2018
    By default, these parameters are :
    [path]
    0=C:/Users/[YOU]/Documents/DAZ 3D/Studio/My Library
    1=C:/Users/Public/Documents/My DAZ 3D Library
    [list]
    control=1
    hidden=false
    empty=false
    joint=true
    pose=true
    connect=C:/Users/[YOU]
    /Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/
    • Current user's folder (where your scenes and presets are stored)
    • All Users' folder (where DIM install the products)
    • Daz Connect folder of the current user
    In your case, GenX seems not be able to find where are stored the Genesis 1/2/3 Essentials
    For example, Genesis
    GenX - Loading figure: GenesisLoading figure ...C:/Users/Public/Documents/My DAZ 3D Library/data/DAZ 3D/Genesis/Base/Genesis.dsf
    Post edited by Noah LGP on
  • Ty Noah,
    I think I should be able to rx engineer something based on your post. : ) Will try tomorrow. BB.
    edited March 2018
    About Generation 4 figures, GenX doesn't detect them, you must load them manually ("Load figure" button).
    Then they will be added to the "Sources" list.
  • Sorry for the long Delay Noah, life has been busy here,
    but your guidance was most helpful. and I would not have figured this out in my own. : )
    Now I have a working Gen1 Gnoll base and thats just what I was after.
    498 x 606 - 33K
    496 x 606 - 30K
  • i seem to be having same issue definition can not be found
    and tried pasting gensis data folder everywhere but it still doesnt work
