request to have "fit to..." added to the contextual menu in the content pane
StratDragon
https://bugs.daz3d.com/view.php?id=50477
if this is a feature you think you might want you can add your support or conversely you can say it's a bad idea a horrendous and terrible idea, however lots of times I have to do the 2 camera switch-a-roo and 5 steps could be condensed down to one if this option existed.
I rarely have anything that doesn't auto-conform on loading, but on the odd occasion where it's something new and I haven't fixed it yet, or have had the wrong item selected, then I simply right click the item in the viewport, and use the fit to option in there.
that option only works if the camera has the figure and the clothing in the same view. If you move a figure outside of the default camera field of view or if you delete a figure and that was moved from the 0,0,0 coordinates and the camera was moved to frame that I need to select another camera or make another camera to get to the clothing, or if you positioned your camera then moved it you need to undo that, then select another camera, so more steps and the potential for mishaps with the camera. If you catch it you can undo but if you didn't realize it then you are 10 steps away from not getting your camera settings back.
The ability to parent an item in the scene tab can be accomplished by dragging the item so it nests inside a figure or by right clicking name, so two ways to parent in that tab but there are none to perform a fit to in that tab.
