hi i wonder if someone can help me need help badly
ok heres the thing i am doing a project  and i need to take a car apart   but theres no way to do it
is there set out there where you can eliminate car parts and leave only the bottom, seats, and tires without roof   thanks so much
  • 3Diva3Diva Posts: 11,981
    I don't know if there is a car that's able to do that, however you can use the Geometry Editor tool to create surfaces that you should then be able to hide.
    Here's a good tutorial on how to use the Geometry Editor tool: https://www.daz3d.com/forums/discussion/42088/tutorial-adding-surfaces-in-ds-with-the-geometry-editor-tool/p1
  • lasagnamanlasagnaman Posts: 1,001
    hi what about ripping the roof offf and putting in my figures hand   thanks so much
  • DiomedeDiomede Posts: 15,398
    edited March 2018
    Which car?
    In addition to the geometry editor, you might try either turning off visibility of individual bodyparts or sending the model to Hexagon for morphs.  Depends on the car model.
    - To turn off bodypart visibility, it depends if the parts have been set as an individual bone. For example, a convertible might have a bone for the roof.  If so, go to the scene tab and click the eye next to the roof to toggle visibility.
    - If there is no separate bodypart for the roof, you could use the file menu to send the car to Hexagon.  Use File : Send to Hexagon.  You would then have all of Hexagon's selection and manipulation tools available to you.  For example, you could select all the polygons of the roof, create a new shader domain, and then set the shader invisible.  Or, you might select the roof, translate the polygons up and send the file back to Studio as a morph.
    1588 x 1001 - 202K
    1737 x 1017 - 209K
    1712 x 987 - 220K
    1769 x 995 - 237K
    Post edited by Diomede on
