This is really annoying
NedKellyNedKelly Posts: 63
I've got an odd problem at the moment. When I try to re-pose the female actor in this scene not all of her moves, some bits remain where they were, at least in the general workspace area. If I do a spot render it's all as it should be. To reset it in the workspace I have to select any body part from the scene tab and turn it off and back on, this resets all the errant parts but it is really annoying as when I'm trying to pose the figure the part that I am moving disappears from view. Any suggestions on how to stop this from happening would be much appreciated.
PS. I did try saving the scene and re-opening it but the same behavior persists.
  • JaderailJaderail Posts: 0
    Umm... WOW! Never saw this one before. I notice a Camera aimed at the FEET in the wrong place in Preview. Could you post a screen shot of that cameras view as well please.
  • NedKellyNedKelly Posts: 63
    Sorry Jaderail, I'v deleted that camera since taking the screen shots but I did check and it is the same for all cameras.
    Just had a thought, I deleted a prop that was parented to the actor, do you think that may have anything to do with it?
    It should not have had any effect at all. I'm still stumped as to what could be doing this. Which figure is it, Genesis? V4?. Maybe something to do with display options? How about a quick look in Prefs, one look at Scene and Interface in prefs might offer a clue.
    It's V5 Supermodel, got a render going at the moment so cant do much until that finishes but here are the things I did try,
    Zero figure pose/shape
    Restore figure pose/shape
    Restore figure rigging
    None of which had an effect
    I know you saved this File so a good test will be, after your render, clear the scene and load a different one without closing DS. If it loads fine I would believe the Scene you have now just had a glitch that saved. You can also try a full PC reboot (Clears all Ram and pointer stacks) Boot DS clean then load the scene again, if you have not done so as of yet. If It still has the error and no others do, it's just a bad Data write some were in the one file.
    Well, whatever it was seems to have righted itself just by closing and restarting DAZ. So now I guess I'll never really know what caused it and that is gonna annoy me more than the problem itself. Thanks for your time Jaderail, but I know this wont be the last time I will be in need of your wisdom.
    LOL! At least you can use the scene. That's better than the way it looked before.
