Anika's Deviations
anikadanikad Posts: 1,919
edited June 2013 in Art Studio
I've been bumbling around for a year or so. I've done a few renders but I don't think I really know anything. Case in point the following render is blurry. I have no idea why. The piece was for a 30 day challenge I've decided to take part in. The music that inspired the render was Cotton Candy by Bonnie pink. So the render does sort of fit because cotton candy is kinda fuzzy. Still I would like to know what I did so that I can fix it.
Post edited by anikad on
«1
  • anikadanikad Posts: 1,919
    These are my 3delight settings.
    457 x 479 - 40K
    Uber Environment settings
    473 x 676 - 52K
    Camera settings - although I have the same issue from a perspective render so I don't know that the camera settings are the problem.
    459 x 505 - 50K
    476 x 667 - 57K
    453 x 297 - 30K
  • Richard HaseltineRichard Haseltine Posts: 108,695
    It's the Depth of Field on setting, and the focal distance isn't the distance to the figure so the figure is blurred. If you look through another view, with the camera selected, there are little widgets to set the focal point and f-stop if you want the effect.
  • NovicaNovica Posts: 23,925
    edited June 2013
    This is going to be delightful when you get it fixed!
    I asked a LOT of questions on a thread about DOF- basically what I'd recommend is creating a camera called DOF so you know that is the one you want to render from- then go to TOP VIEW- put the white ball on top of the character's head, and there will be two planes visible. Put the first one in front of the character, and the second one behind the character. Adjust your settings (focal length, etc) to where you want it, but keep your character in between those two planes. EDIT: Just explaining this just in case- not assuming that you don't know it. I DID read that you said you were having the same problem throught the perspective view. I haven't done DOF in a month, but that sounds whacky?
    Cathie
    Post edited by Novica on
    Thank you both for the info. If I understand correctly I need to make sure my focal distance is the same as my Z translate? Changing that seems to have fixed the problem in this case but know if that is a one off solution.
    So this render was done for Day one of the 30 songs, 30 works challenge:
    http://30songs-30works-30days.tumblr.com/
    I've decided to call it Candy because it was inspired by the song Cotton Candy:
    http://www.youtube.com/watch?v=j8Nu2_Hbzs0
    800 x 1200 - 109K
    Items used in the Candy render.
    Aiko 5
    http://www.daz3d.com/aiko-5
    Pure Hair Bubblegum
    http://www.daz3d.com/pure-hair-bubblegum
    Cute Bow Heels
    Bottom Ruffle Skirt
    http://www.daz3d.com/br-skirt-for-genesis
  • SiscaSisca Posts: 875
    Not so much that focal length = z translate but that what you want to be in focus is within the boundaries of the depth of field as was mentioned above. In the screenshot you want to make sure that what you want in focus is between the 2 light blue lines anything outside of those lines will be fuzzy.
    Basically, DoF is determined by the focal length of the lens (Focal Length (mm) setting in the camera settings of the parameters tab) and the F/Stop. Adjusting either of these settings will alter your depth of field.
    It's fun to play around with as you can get some really interesting effects when you learn how to use it.
    1603 x 894 - 180K
    Thank you for that explanation. I'm going to make sure I play with this ... now my pc has stopped crashing while rendering.
    Managed to render something again. Far too dark. Is there a way to tell if something will render dark, even though it has lights included?
    600 x 600 - 114K
    I re-rendered adding a distant light this time and amazingly my pc still didn't crash. I didn't want it too light so turn the intensity down to about 50%. It still might be a bit too dark though. Also I think the shadow is too sharp, will have to play with this some more.
    600 x 600 - 134K
    How many lights do you have in the scene?
    It may take adding another light or two to act as fill lights though these don't need to actually cast shadows
    To soften the shadows you can adjust the shadow softness on your main light. I usually adjust it up to about 20% and tweak from there.
    While you're working on getting the lighting right you might want to make smaller, lower quality renders until you get what you're looking for and then render out the quality and size you want.
    edited August 2013
    http://www.daz3d.com/forums/discussion/19756/P1155/#407972
    You always pop in and support my thread, so for my new series that I was planning for this next week, I figured I'd use a similar pose like your figure, dark clothes like yours, and a night setting to show you what a spot light, distant light, and a linear point light can do. I took each one by one (as planned, as I'll be showing the combinations of lights) so that might help you pick one or two you can even add to your scene.
    It's better to use a combination of lights at lower settings (IMO) than rely on one or two lights at higher settings. You'll see the difference as each is added- I'll be turning DOWN the intensities of some when others are added.
    Skim through the 1-4 sets and see if there's anything you like. I've given you the coordinates of my own personal light sets that appear in my art studio. :) Shown with and without masks on the figure.
    Below is TTATT 1 with higher intensity setting, from the series, and then the series progresses to show the combination that will yield a brighter figure using three lights, all different. All coordinates are given for you. It's designed to be a learning series- see where lights can be effectively placed, then tweak. (Novica's lights TO TRY AND TO TWEAK (TTATT)
    Not trying to hijack your thread- I did this with you in mind when I chose the first series subject.
    600 x 600 - 61K
    600 x 600 - 48K
    After a week off work I've finally got around to doing some rendering. Thankfully my pc didn't explode. This is a test render
    Used
    Amber for Aiko 5: http://www.daz3d.com/amber-for-aiko-5
    PH Darling: http://www.daz3d.com/pure-hair-darling
    Lacy Dress: http://www.daz3d.com/lacy-dress
    The Ant Farms Base Camp: http://www.daz3d.com/base-camp-vol-1-3-bundle
    Lighting: the barefoot lighting set in genesis essentials
    600 x 900 - 195K
  • TjebTjeb Posts: 507
    Looks nice.
    Now, just for learning purpose, create a small plane underneath the base, so the base rests on something.
    With a nice reflection.
    Then turn on the shadow of your light.
    Render again and watch the difference.
    Thanks for the suggestion tjeb.
    I've added a plane to the bottom. I need to play with this some more to get longer shadows.
    550 x 825 - 177K
    Today I've been playing with Weapons of Beauty: Kunai for V5: http://www.daz3d.com/new-releases/weapons-of-beauty-kunai-for-victoria-5
    I'm not really and expert in these things but I think she looks quite Korean.
    Dogz 3 in 1 skinny outfit
    http://www.daz3d.com/3-in-1-skinny-outfit (trousers & top)
    xTreme heels
    Eva1's urban shaders
    http://www.daz3d.com/urban-environment-shaders-for-daz-studio
    600 x 600 - 133K
    I'm using Chablis lights and the first time I did the render this happened. I quite like the effect. i'm guessing it's too bright. Chalis is a darker character.
    600 x 600 - 146K
    edited May 2014
    No lights, Mavka's leaf dress (http://www.daz3d.com/mavka-starter-bundle) and hair plus Michael 5. What can I say? I decided to try out all my female outfits on male characters. Michael looks pretty good, no?
    600 x 900 - 142K
  • mori_mannmori_mann Posts: 1,152
    *grins*
    Said it before: ther's no joy like trying dresses on your guys.
    There is a whole thread in the commons dedicated to doing just this. http://www.daz3d.com/forums/discussion/13326/
    edited May 2014
    mori_mann said:
    *grins*
    Yep, this is probably why I like Genesis so much. Nothing to do with the technological advancements. All about dressing boys in dresses. On that note Michael has moved on to Adventure Outfit (http://www.daz3d.com/adventure-outfit).
    600 x 900 - 171K
    Thanks. I'd forgotten about that thread.
    edited May 2014
    Michael has gone all Vogue with All that Jazz for V4 (http://www.daz3d.com/all-that-jazz-for-v4). I'm really impressed with autofit.
    600 x 900 - 150K
    Oh now that one is cracking.
    Anikad, you crack me up! :)
    thanks ladies. Will probably do a proper render of M5 in the Jazz outfit. I still have an old dell box with 4gb, so rendering can be a bit of chore.
    Today Michael strikes a pose in Dogz's 3 in 1 skinny outfit http://www.daz3d.com/3-in-1-skinny-outfit
    Interesting historical titbit - at the turn of the 20th century boys were associated with pink and girls blue. Not until the 40s did that change.
    http://www.theguardian.com/science/2007/aug/25/genderissues
    600 x 900 - 177K
  • starionwolfstarionwolf Posts: 3,670
    I like how the color of the shoes match the color of the shirt.
