Adding to Cart…
I have it set to load a default scene including a camera, well three.
If I disable the loading default scene, so no camera, or anything else there, should it work?
If so, well it still hangs as previously.
It creates the paving straight out based on the X x Y settings you use (number of repititions of the base layout pattern, the Paving Design). Idoes not follow ground (which I looked at, but that in combination with complex tiling was just way to complicated to get working fast enough and robust enough)
But you can easily say make me a 6 feet x 54 feet paving ( if the base size is 3 feet, thats a 2 x 18 paving)
Thanks for the answer, it's nice to know what are the actual capabilities of the product before making a decision (I will definitely pick it up at a later date, because results look just that good, but I am on a bit of a tight leash at the moment).
Thanks, I try to be honest with what my products capabilities, and thanks for the kind words. I know at least one PA has been asking about making props and paving sets and designs directly usable from Auto Paver, hopefully more will come. The foundation is in place, now imagination sets the limit.
Update is now live!
got it thanks.
I still have the same error.
You still got the error? Did you get 1.0.1?
I just tested the downloaded version and it is 1.0.1 and I no longer get the hang due to a deleted camera.
If you add an empty group, do you have the problem?
Ditto - same thing..
Start DS (it creates Default Camera automatically).
Create Primitive (Plane: 10m with 128 Divisions)
Select Plane, go to Surfaces, selct Material zone
Select Auto Paver,dse - AP Cobbles, Pavement repetitions X and Y set to 3., click Lay pavement ...
7 or so minutes later, DS is still 'Not Responding' The Script dialog box still says Version 1.0 for me, despite having installed the updated versiosn via DIM, I am guessing that is not right?
The update only was only for Paving Set Builder (which dont create a group), and I havent reproduced any issues with Auto Paver.
Sounds like two differnet issues, and Simons one is ever weirder. Do you have a log Simon?
And Which DS version are you running Simon?
And : Which method of installation did you use? DIM, Manual or Connect?
Latest (4.10.0.123) 64-build, running under WIn 7 Pro. Program, and content, installed using DIM. Program goes to default location, content goes to a directory on my D: drive.
Log file doesn't seem to give much from what I can see, but the period in time shows:
2018-03-08 11:07:55.737 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-03-08 11:07:55.737 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
2018-03-08 11:07:55.738 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-03-08 11:08:15.839 Loading script: D:/DAZ 3D/Studio/My Library/scripts/code 66/auto paver/auto paver.dse
2018-03-08 11:08:36.582 File loaded in 0 min 0.0 sec.
2018-03-08 11:08:36.585 Loaded file: AP Cobble 16x16 1.duf
And .. that's it.
That is really weird as that one I cannot force. I'll make a build that logs heavily and send to you if it's, OK, I have no clue what the issue is but I guess I'll find out, might be something silly, like a setting in DS that makes things happen in strange ways.
Ok, anything I can do to help, let me know
You got a Message ;-)
Got it! I am out at the moment, but will check it as soon as I get back!
Thank you!
My error is the same as originally reported. I use DIM btw.
Is that Paving Set Builder still or as Simon the Auto Paver script?
We're working on it but I still cannot reproduce it but we're getting closer, Simon is running log versions so I get to see exactly was does and does not happen.
*covers screen with hands* See eaxctly ...?
@nicstt: Which Windows version are you using? I'm beginning to think it's related to that.
Windows 10 (which I loathe btw);paving set builder.
2018-03-09 20:50:44.705 Loading script: E:/Documents/Daz 3D All Libraries/Custom Scripts/Scripts/Code 66/Auto Paver/Paving Set Builder Debug.dse
2018-03-09 20:51:01.598 WARNING: Script Error: Line 1206
2018-03-09 20:51:01.598 WARNING: TypeError: Result of expression 'oContentFolder' [null] is not an object.
2018-03-09 20:51:01.598 WARNING: Stack Trace:
<anonymous>()@E:/Documents/Daz 3D All Libraries/Custom Scripts/Scripts/Code 66/Auto Paver/Paving Set Builder Debug.dse:1206
2018-03-09 20:51:01.598 Error in script execution: E:/Documents/Daz 3D All Libraries/Custom Scripts/Scripts/Code 66/Auto Paver/Paving Set Builder Debug.dse
this is the log; I'll send you a link to the dse file.
yes, that was we just found, I get "no such file error" when loading the selected prop, which was a great lead, working on it right now to see why.
/Totte
Good news indeed, the issue has finally been solved with help from both users (that has been invaluable in testting this) and the DS team. A final update is in the works after some final testings that will be made.
Glad it's sorted.
Thank you for your work in quickly and resolutely tracking this down for a thurough stomping - bugs deserve it
I really like this product - very useful.
Update to 1.0.2 should now be live in DIM.
Yup downloaded it, but not used Studio this evening as I'm busy coding. I have to squeeze in both addictions :)
OK - I hope everything is solved now.
Hi I just got this set and I upgraded to
D|S 4.10 and after a few problems it has installed. I am now able to open the scripts. My problem is that I do not see any paving sets in the auto paver interface where you show the built in sets populating the window on the left. its just empty and of course I have not yet made any sets so none of the radio buttion settings shows me any sets. I did a finder search and they seem to be in the folder. for example I found ap cobbleset.appset and many other sets in this directory
E:\Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_50571\scripts\code 66\auto paver\paving_sets
any ideas?
it looks very cool and I can't wait to build using my own textures
Cloud installed, hmm, try installing via DIM as I do not know if it does work via cloud and it's impossible to test or debug but I guess it won't work as the description files might be encrypted as well,
/ Totte
