Canary's Color Palette - color values conversion helper
Canary3dCanary3d Posts: 2,033
Ok, this is a strange one, but you might find it useful if you:
1. Use a modeling app with an "eyedropper" color picker and want to quickly import a lot of colors into Daz Studio
and/or
2. Want to edit material file diffuse color settings in a text editor, but don't want to deal with the number format used in DSON files.
This is a prop with 16 clearly named mat zones that you can color in your modeling app, import to Daz Studio and then grab values from the surface tool or save to a material preset for copy-pasting into your other material presets.
If none of that makes sense to you, you don't need this helper! But if it does make sense, the readme explains a little more about how to use it.
https://www.dropbox.com/s/86o50jpxy2t3f9d/Canarys_Color_Palette.zip?dl=0
