Daz 4.6 rendering problem.
The refracted and reflected items have big noise on the edges. Reducing shading rate only a little resolving this problem. Daz 3 haven,t such problem in the same rendering settings. The result was correct.
Excuse my bad Enhlish.
  • JaderailJaderail Posts: 0
    What are your Render settings? Much more than just Shading Rate applies to Glass, Refraction and Reflections.
  • edited December 1969
    With simple reflection is same problem.
    954 x 554 - 223K
    One still.
    946 x 554 - 223K
    One still
    1000 x 554 - 228K
  • ruekakaruekaka Posts: 348
    I had similar problems. See here: http://www.daz3d.com/forums/discussion/22758/
    Just increase the Max ray trace depth and the pixel samples.
  • ReDaveReDave Posts: 815
    There have been optimisations to 3Delight since the DS3 days, and apparently the speed-up is related to "clever" tricks in the reflection and refraction handling. :-S A lower shading rate should be the solution, but I'm going to try the pixel samples idea later.
    In this reason I still using Das Studio 3.
    edited June 2013
    Pixel samples are the issue, just as they play in DOF they play in this as well. Mine never fall below 16 for any render.
    EDIT: The DS3 3Delight render engine is over 4 versions below the one in DS4.6.
    Post edited by Jaderail on
    Can't replicate any improvement due to higher Pixel Samples, but I am on 32 bits and we have a max at 16 samples. I do vaguely recall this came up once before, but I don't recall what was the upshot, perhaps very high Samples in 64 bits do help.
