Eyebrows for Toons are white in render
in New Users
I'm using toon gen2. Female. I clicked on Scene: toon female and then clicked Brows, then material. It looks like it put the brows on but when I render they're white.
If I spot render in 3Delight, the brows are there. I've picked the iray options so that shouldn't be the problem
I figured out how to attach an image
You need to apply the toon hair material to the eyebrows.
Thank you Barbult! that's got it. I didn't click on the brows before applying the material. I thought if I applied right after the brows it would work. Look good now yay!
