Vyusur's studio experiments
2
  • VyusurVyusur Posts: 2,235
    Thank you very much, Ted! It's Fractalius filter for Photoshop. I don't use PS for a while. So I use all those filters with Affiniti Photo. And what is "Line Render 9000"?
  • DiomedeDiomede Posts: 15,393
    Line render 9000 is a render plugin for Studio.  It is sold here in the Daz store.  I dont know much about it, but I see some results occasionally posted in the forums.
    https://www.daz3d.com/linerender9000
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    I love Alina too and am interested in what plugins or post work you used.  Very nicely done.
    edited March 2018
    Worlds_Edge, thank you for your kind words! I'm glad that you like her. I often use ToonyCam Pro for my outline renders and almost never use postwork. Here is an example of what result ToonyCam can achieve.
    1000 x 800 - 1M
    Post edited by Vyusur on
  • IceDragonArtIceDragonArt Posts: 12,832
    Is Tooney Cam for 3Delight or does it work in Iray?  These are very cool!
    IceDragonArt, ToonyCam is 3Delight scripted render. It doesn't work with Iray.
    Okay thanks!  That's what I thought but couldn't remember.  Looks great though!
    Yes that looks really good, and amazing that it didn't require post work.  I apparently have toony cam, but I purchased it before I knew the diff between iray and 3delight.  I've only used 3delight once before.  This is a good argument for perhaps learning more about it!  Thanks Vyusur.
    edited March 2018
    Sonja, Worlds_Edge, thank you for the comments.
    The other way to achieve toonish effect is to use toon shaders. Recently I messed around with 3dl toon shaders. Here is a couple of resulting pictures I could achieve so far. It works fine mostly on simple models, because it's no need to apply those shaders to a ton of content placed into the scene. And this method uses standard 3dl render engine instead of scripted.
    1300 x 1300 - 721K
    1300 x 1300 - 897K
    Nice renders! Does it come with its own script or is it using one of the standard scripts?
    Sven Dullah, thank you for your comment. As for ToonyCam, it came with it's own scripts. I don't know to what extent those scripts are standard. As for the toon shaders used in my recent images, they were mixed by me in shader mixer.
    Just uploaded a part of my recent Blender modeling project.
    Great video!  Love the music also.  Makes me want to model a couple more custom characters.
    Thank you, Ted! Glad you like it. Good luck with your custom characters!
  • SileneUKSileneUK Posts: 1,977
    Vyusur... do you rig in Blender or in Carrara?  Sorry if you have explained elsewhere, I just found your videos... great modelling! You and Dio are doing exactly what I should be doing. Time to learn is a big problem right now... hope that changes this autumn.
    yes  Silene
    Silene, thank you for your comment! I tried to rig in Blender at the very beginning of my experience in Blender. It was frustrating. The easiest rigging for me is in Carrara.
    Do you use a skeleton from eg a Genesis figure or do you get them elsewhere or build them?
    I build skeletons from scratch.
    1300 x 1852 - 1001K
    1300 x 1852 - 2M
    487 x 629 - 340K
    800 x 652 - 432K
    779 x 665 - 520K
    788 x 629 - 482K
    629 x 706 - 519K
    Hmmmm.... I was thinking human hands and feet and all those hundreds of facial bones and wondered if it was possible to detach eg an early Genesis figure's rig, remove the character and put my own character in and use the 'stolen' Genesis rig. Is that possible?  surprise Silene
    I don't know. I didn't try this method.
    edited July 2018
    I  believe you can substitute geometry in the figure setup pane. Not positive and not sure that you can do it for something like genesis. I sort of remember doing it once for my cyclopstritch. I had rigged an early version, later updated the model, and then substituted the new geometry for the old in the figure setup pane so I wouldn’t have to start the skeleton over again.
    Post edited by Diomede on
    Hmmmm... thanks. Will file that away for the next project step. Still working on animals right now.  But will keep my eyes on you and Vyusur... you are both very inventive when it comes to character creation!  yes  Silene
    edited August 2018
    canseled
    edited May 2019
    You never know what you will come up with when modeling while recording. Here's an example of a recent ear modeling. Just improvising.
    edited May 2019
    Time-lapse of an ear modeling above scanned head workflow in Blender 3d https://youtu.be/y-QzNu_d2Jg
  • algovincianalgovincian Posts: 2,669
    That was excellent, @Vyusur - thanks for sharing! Music was great and had a "How it's Made" vibe yes
    - Greg
    edited May 2019
    Greg, thank you very much for your nice comment! It made my day!
    edited May 2019
    Recently playing with NPR styles:
    1000 x 1300 - 2M
    1000 x 1300 - 844K
    1000 x 1286 - 1M
    1000 x 1300 - 1M
    1000 x 1500 - 609K
    1000 x 1300 - 2M
    edited May 2019
    A couple more:
    1000 x 1300 - 2M
    1000 x 1000 - 1M
    1000 x 1000 - 2M
    1500 x 1950 - 3M
    Veronika, I'm loving these NPR styles.  I'm a huge fan of NPR, as you know.  You demonstrate such subtle control.  yesyes
