Where is PowerPose?
barrieM
Just started to try G8 but there appears to be very few facial controls I think I need PowerPose but can't find it in the store.
barrieM
Which version of DS are you using (Help>About Daz Studio)? Do you have the PowerPose pane open (Window>Panes(Tabs)>Power Pose)? If you are looking at the Pose Controls (in the Posing pane or Parameters pane) then those are just convenient remote controls for the face bones, and there are only a limited number of them in the base - for more you'd need the Genesis 8 Female Expressions set, or another expression set.
Thank you, found it. I thought it was a plugin that had to be purchased. If I buy the G8 morphs, will they all be accessable through Power pose as well as the regular sliders?
They would be regular sliders - but with Power Pose you should now be able to create your own expressions.
