How to transfer V4 model morphs to Genesis 2 model
flashmoyoflashmoyo Posts: 12
Hello all!
I currently use Poser for my renders but the Daz3D auto fit has caught my attention and I would like to use it along with the Genesis 2 model. The problem is that I own and use a great number of V4 clothes which I need to continue using.
The project that I have been working on requires that all the clothes that I render are posed on a specific body morph. The model that I have been using is FRAD-Lexi V4. (http://market.renderosity.com/mod/bcs/index.php?ViewProduct=61731)
So I have 2 questions for all of you.
Question 1: Is there is any way to add the exact morphs of the V4 model to the Genesis 2 model so that if I render the two models at the exact same pose and I put one render on top of the other the result would be identical?
Question 2: Is there a way that the pose that I use on the V4 model to be used on the Genesis 2 model and produce the exact same render?
Thanks in advance for all of your help!
    You can use this : http://www.daz3d.com/genesis-generation-x2
    It transfers V4 morphs to the Genesis 2 figure. You would also need this : http://www.daz3d.com/genx2-addon-for-genesis-2
    After the transfer process, the result is not likely to be 'exactly' the same, but certainly very close to it.
  • fixmypcmikefixmypcmike Posts: 19,701
    Vhardamis said:
    That will allow you to use the skins, but not the morphs.
  • hiyashi_yasurohiyashi_yasuro Posts: 32
    Which one would you need if you want to use the Heavenly Bodies morphs(http://www.daz3d.com/heavenly-bodies), the Kirei no Kanjou(http://www.daz3d.com/kirei-na-kanjou-for-aiko-3-0) skin or the V4 Elites?
  • Tramp GraphicsTramp Graphics Posts: 2,422
    flashmoyo said:
    Hello all!
    From my understanding, to transfer V4 morphs to Genesis 2 Female, first, use Gen X2 to transfer them to Genesis 1, then transfer them from Genesis 1 to Genesis 2 Female. Its a two-step process.
    flashmoyo said:
    Hello all!
    No, you don't have to use Genesis 1 as an intermediary, you can transfer directly from 4th Gen to Genesis 2.
    flashmoyo said:
    Hello all!
    No, you don't have to use Genesis 1 as an intermediary, you can transfer directly from 4th Gen to Genesis 2.You may be right. That might only be for autofitting V4 clothes to G2 figures that you need to autofit to Genesis 1 first.
    flashmoyo said:
    Hello all!
    For 3rd Gen clothes to Genesis 2 you need to autofit to Genesis 1 first. For V4 clothes, if you don't have "Victoria 4 for genesis 2 Female" you can do it with Genesis 1 as an intermediary; if you have that product you can do it directly.
  • PuzziePuzzie Posts: 11
    Hi
    I know this post is old and stale. I am a (was a) poser user long ago (like 9 years). I am starting to try and get back into this..
    Lots of differences. Not sure I will survive the battle. That being said. I used to keep up on some of the stuff and I did buy (back when G2 came out) V4 for G2F
    I cannot find a shred of documentation on how it is supposed to work. No docs on the DAZ website (that I could find). No docs in the .zip file. I can't seem to find the figure in my DAZ Studio library.
    Any suggestions? Thanks in advance
