Help with applying Marauder armour
orbital
Ok I don't use Daz studio very often, but today I purchased this
http://www.daz3d.com/marauders
It's installed in my content library but when I click to apply to a Genesis figure nothing happens. Do I need to purchase something else to make it work, or am I missing something simple? Judging by the description it should just load onto a figure automatically.
I don't have this product so I cannot check but just to make sure your are trying to load the mesh (object) and not a Material to Genesis are you. That is the forst common mistake so I need to ask the question and go from there.
If you are loading the mesh then have you tried click, hold and drag the mesh preset icon to Genesis.
Well it comes with a body suit mesh which should load. But every time I click on it I get the message no importer format for the file can be found.
Which sounds like you are loading a Matarial preset as that warning is what I get if I try to load a Material Preset opposed to the mesh. The Smart Content Icon will have a coloured bar naming what it is, Wardrobe, Material etc.
here is the readme http://docs.daz3d.com/doku.php/public/read_me/index/13312/start which says the mesh will be named as Accessories
it simply DAZ mistake about meta-data.
I understand, this product often up-dated about meta-data or etc before.
I seldom used it, but today I checked it again.
the Wardlobe>Fullbody categorized bodysuit.duf type is material.
(but I do not know, the material is for which prop or etc ^^;
sometimes daz mix up other product ,, but it seems one of material preset
to use for something ^^;)
HaHaHa,,,, I often be angry about meta-data missing or daz often up-date same product DIM,
then cause another new erroer,, about conetnts which I bought.
this is one of that. I have no tention to keep angry,, so you may better if you hope to correct meta-data
send bug-report. and hopw to ask them "For What ?"
Now I have waited another product up-date (remove bug)which almost one weeks before I send bug report.
the product is removed weight-map,,after up-date the DIM zip,
then the product up-dated because of formular erroer which I have reported.
so that,, DAZ remove formula erroer, then remove weight-map too.
HAHAHAHAHA ^^; Can you laugh it? you are good man.
Oh,, I understand,, the body suit duf is material presets to apply genesis skin .actually.
lets check,,select genesis, then apply again. it is no mesh . simply change genesis skin as body suit .
so that it is not bug. usually we think body suit is not material only.
sorry. DAZ . but you have send many bug product by DIM to me.so I do not care much.
anyway please DAZ correct my reported bug.
