visible in render / visible in viewport
I have a cube,
Under properties, if I set "visible in render" to false and 'visible' to true, then predictably the item is visible in the viewport, but it doesn't render.
But if I set "visible in render" to true and 'visible' to false, the item is invisible in the viewport, but for some reason it doesn't render.either.
Why is that?
Im using DazStudio 4.10. 3delight render. I'm not on my main pc so I haven't tried this in iray.
Post edited by BradCarsten on
Currently you can't make things invisible in Viewport but visible in render, however
In DAZ Studio : Incremented build number to 4.11.0.36 http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#private_channel
Oh that's a pity.
Thanks for the additional info.
