Lock Poses For Daz Like Poser???
was wondering if anything of the sort was out there, Im not even sure if you can lock actors in Daz 4.5... Obviously I'm new to Daz have been using Poser.... I like poser but Daz is where its at plus its free!!!
But for those who may not know what Im talking about, there was a set of pose files that would lock your characters Head, Hip, Torso, Legs, Arms etc. so that new poses applied wouldnt affect said locked items....
Never tried this but if you expand your figure and Select the part then open the Parameters tab you should be able to LOCK all the movement parameters. Use the Lock icon on the sliders.
About .duf and dsa poze presets, with ctrl holding down, then click the poze presets,
you can select node which apply the poze.
with mix the locking some nodes rotation value (in parameter tab ) we can apply poze more fexible.:-)
eg)
first select "plevis" and apply poze.duf (dsa) files with ctrl holding ,
then set "selected" , "reclusive" .
your figure may only change poze under plevis, keep the pozing of upper body parts.
but about .pz (poser type pose files) , it seems not work. or I have not found the way.:ohh:
so that may need to lock each parameter (node rotation).
and if you get posemaster (plug in tool for daz studio), you may more easy mix pozing.
it work about .pz files too.
Hey That did the trick! Im assuming there aren't any locking presets out there but atleast I can select and lock multiple items at once.. Thanks you my friend!
Thank you for this info! mostly all my pose files pz2 but Ill be sure to remember this for later use. I will definitely have to look into this posemaster
