Animate2 lip sync with Genesis 3??
I've discovered that aniBlocks for Gen 2 have to be converted to work with Gen 3. I bought the script and am working that out. But it suddenly struck me...will the lip synch in aniMate2 work with Gen 3? The visemes it maps to the character are nothing but facial poses after all. I have a sinking feeling that there may be no way to do lip synch in aniMate2 with Gen 3. Anyone know?
Dont let anything sink yet nor let anyone man the life boats, it does work.
But aniMate2 doesn't do any lip synching itself, you need to use the 32 bit version of Studio to have the Lip Synch plugin work. (Or use Mimic Live!) Studio's 64 bit version doesn't have the Lip Synch plugin. Additionally, you have to make up your own Mimic Configuration File (.dmc) to tell LipSync/Mimic the correct names of the morph/pose channels. Which DAZ forgot to put into the base package for G3F... AGAIN!
But you can make up one your own easily: take one of the .dmc's within the "C:\Program Files (x86)\DAZ 3D\DAZStudio4\plugins\dzmimic\Configuration_Files" directory, make a copy, rename it like "Genesis3.dmc", and replace all text within it with the following:
Save it then and from now on you can use your new, selfmade .dmc in the Configuration File slot of either Lip Synch or Mimic Life!. Don't bother about the values, even DAZ used, if I remember correctly, identical values for Genesis and Genesis 2. Only the channel's names were changed.
Hope that helps
I am having trouble making basic Genesis figures talk using standard DAZ lip sync plugin. I tried DAZ Studio 4.7 and 4.8 32-bit versions, used Genesis.dmc and Genesis2.dmc from the basic installation, tried the code, which Arnold suggested for Genesis 3, but I can't make basic Genesis figures say even standard phrases included in the installation. Nor Genesis, nor Genesis 2, nor Genesis 3. Each time I start Analyze, I get "Mimic TalkBack analysis error: TALKBACK_INVALID_PARAMETER_ERR: one or more of the parameters is invalid". What may be the problem?
Looking for the best way to animate lip sync.
I create half hour programs that use multiple characters and prerecorded actors voices. I use Daz 4.7 64 bit, with both Genesis and Poser characters. I looked at mimic, but wasn't convinced it would work with 64 bit, or with pre-recorded voices, or with all characters. What plugin would work in this situation? Thanks in advance.
I've got Mimic working, but it's designed to work off of your computer microphone. I think there might be a way to map the playback audio to your microphone channel in Windoze. Going to have to work on that next.
Thanks Arnold. Mimic is up and running!
I know it's two years later, but this forum literally just saved my life!! Was so stuck with the G3 LiPSync... thank you!!
Thanks Arnold
bless your sould arnold!! saved my ass
