why do my loaded morphs do this
WendyLuvsCatz
I often get this loading a morph I shaped from another object in any software and no idea why
the vertex order matches
that is the morph obj on the left and big cat 2 with it applied on the right, it was Adam Thwaitt's bulldog with the big cat shrink wrapped to it then smoothed
it even retains the UV mapping
the normals are all on the outside
this is personal use only and renders before some bright spark chips in about shrinkwrapping and the EULA
and an example
it happens randomly on many things others work fine
Zbrush and scupting AM's Raccoon with my own morphs not giving me much love either
the eyes etc all in place but the body bizzarely transforms
actually an obj works better
but my sculpting sucks and so does my projection painting
How are you sure the vertex order matches? It certainly doesn't look to be the case.
well morphloader accepts it and creates a messy morph
I cant tell exactly what the problem is, also I cant tell exaclty what you did, but could it be a scaling issue of the morph target obj? This could explain why at least some vertices tends to move to the floor.
Maybe you try to sculpt on a figure shape that is actualy not the real base shape or it isn't in base possition/scale try to 'Zero' the figure pose/shape first - you could also try the "reverse deformation" in the Morphloader pro settings so you dont have to care that much about the real base shape.
Test your obj file by importing it as a static object to DS and see what it looks like.
Maybe it could be that the figure you try to create the morphs for isnt saved properly as a content file to the library yet - so DS dont realy know the base shape or the shrinkwrap shape/morph.
You see I'm just guessing maybe other have better suggestions.
That means it has the same number of vertices, not that they are listed in the same order.
my first images seem to have vanished which makes this post very unclear
the latter ones were oddness using goZ as opposed to obj import from Zbrush
the missing images were from the shrinkwrap modifier in Blender which sometimes works other times gets the results you cannot see in my first post.
but hopefully here
Check your options for import/export in Blender - there is one that offers Preserve Vertex Order or something else, I suspect you have the something else option on.
Hi guys.
This random "object trapped in a large,plastic rubbish bag"
phenomenon, happens to me as well on occasion
however with MDD& object files exported to Maxon Cinema4D
An incorrect vertex count will simply cause my MDD importer
to reject the MDD file with a detailed error message, example:
INCORRECT VERTEX COUNT!!!!** object count-62745
MDD file-73492!!!! ''
Sometimes it randomly accepts my MDD files and loads the number of frames baked in the MDD animation and My target .obj in C4D will actually move during playback but is trapped inside the large, stretched to the ground " rubbish bag".
On Two oocasions I thought I had tracked down the culprit.
first it thought it was from animating the mesh in the 32 bit version of DS and exporting from the 64 bit..turned out to be a false positive.
I then noticed it happening whenever I used one of the old first generation anibloks with feet pointing skyward and corrected them with the "high heel offset" option in animate2.
But later it ..happened with an animated mesh where I did not
even use an aniblok.. another false positive
I believe this to be a real bug, hidden deep and Ellusive.
However I can not intentionally reproduce on demand for a proper bug report.
when it does happen I simply make a random Change to the animated Figure such as different hair or shoes and this solves my problem with with a new .obj/MDD export to C4D so not a true show stopper, but still............
.....stumped
yes as I said this was just an example
iClone 3Dxchange does it too loading morphs
and exported and reimported obj with a few vertices moved
it happens in Carrara as well and I never can predict why as another file done the same way works fine
