Problems with Eyes in Rendering (3d Delight)
I have had this issue in the past but cannot for the life of me remember what settings I changed to corrected it. The white under the eyes is only visible in rendering. I would appreciate any tips :)
    That's the tear. You can adjust the settings in the surface pane. If you want it off just set opacity to 0 and make sure the multiply specular through opacity is turned on. Or you can adust the glossiness to achieve a different look, a higher number creates a smaller/tighter highlight. Basically play with diffuse strength, opacity and specular/glossiness settings to get the look that you want.
  • Thank You!
