VS Feathered Top for Genesis (Fixed!)
Hey guys, here's a basic freebie outfit for Genesis.
Basic top with a feathered midriff with long and short options.
Very basic pants, only suitable for use under shirt as they are rather low...
Several textures are included.
Daz Studio 4.5+
Please let me know if I went full retard and forgot a file or something...:P
Edit: There was an error with file paths. I wiped it all, started fresh and repackaged it and reinstalled it. Sorry about the inconvenience!!
http://www.ShareCG.com/v/69353/view/21/DAZ-Studio/VS-Feathered-Top-for-Genesis
Post edited by Saiyaness on
Thank you, I'll give it a try in a little while. It looks very useful, much appreciated.
Thank you. We'll give it a try today! :D
I get a few errors when loading some of the items, but it all still works funnily enough :)
Loading the pants textures, they still load OK as far as I can see.
Error - Missing assets
/data/Rhiannon Grundy/VS Feathered Top/VS FT Pants/UV Sets/Rhiannon Grundy/Base/default.dsf
When using the 'No Sleeves.DUF' But it still works
Error - missing assets
/data/Rhiannon Grundy/VS Feathered Top/VS Feathered Top/UV Sets/Rhiannon Grundy/Base/default.dsf
Does that help any?
Crap! I'll check it out! Basically it just sets the sleeves opacity to 0 but I don't want it buggy. I'll have a look. Thanks!
Weird. I had it in the Rhiannon Grundy folder initially but then I remade the product and resaved it all to the VSaiyaness folder and all of the directories that I am using on my computer coincide with the directories I have set up in the folder that I distributed. I'm new to this. I don't know what to do. :p
Sorry for the hassle!
It's no hassle at all, thanks for making these, they are really good.
The wrong data path is in some of the DUF files for the Pants textures. There are a few with the old path, but they should be easy enough to change. I can do it for you if you like?
Sorry, had to go to bed last night :p I realised in bed that I had already made the pants a figure/prop asset so they would have already had that file path, even though I thought it would have changed when I re-saved them as a different figure/prop asset.
I'll just re import the original mesh again for both and start from scratch. Thanks for the heads up! :)
I'm glad you have it figured out.
It's bedtime here, long ago actually at my age. Thanks again for your work.
hi hun i had same error as jimmy but thy still loaded and tex went on ok thy posed well tpo well done hun pic for u to see
Okay! For the 57 people on ShareCG who downloaded it already, I sincerely apologise!!
It has now been fixed. There should be NO file path errors.
I wiped it from my system and started fresh and remade, resaved, repackaged it all and added the UV maps so people can retexture it. I installed it back into my runtime and everything worked great.
Sorry again!
....it better bloody work anyway :p
Thankyou! I'm sorry about the annoying error messages. You can redownload it if you want. It SHOULD be fixed. And I'm totally chuffed to see someone use it! I apologise for the buttcrack pants :p
Great outfit, here's a render I tossed together real quick. But I'm definitely enjoying the outfit, thanks!
Woohoo! It looks awesome! I'm grinning! Thanks for showing me! :D
