All of my animations start at once?
robsdroid215robsdroid215 Posts: 2
edited February 2018 in Daz Studio Discussion
All of my animations start at once.
I am very new and my terminolgy may be way off.
I drag a Genisis 8 Female model into my scene.
Then I click the Posing Tab.
On the bottom time line I right click and 'Add empty block' and drag the sloder to the end of the empty block
Then back to the posing tab and I use the ARM sliders and move her arms all the up, then down then up, then down adding empty block each time.
When I click play all works fine... Her arms wave up and down several times the way they should.
Now the problem is when I add another empty block and move her legs all the way up... When I click play her arms and legs move at the same time and not in order..
I tried adding a new track and the same thing happens. I did notice a long arrow point to the beginning I have attached a screenshot to show you what I mean.
Basically I want animation to happen in a sequence. I don't want all animations to start at the same time.
Thanks
Post edited by robsdroid215 on
  • BeeMKayBeeMKay Posts: 7,019
    >EDITED because I Misunderstood>
    Post edited by BeeMKay on
  • All of my animations start at once. I want the arms to move then i want the legs to move. I do not want the arms and legs to move at the same time.
    On the bottom time line I right click and 'Add empty block' and drag the slider to the end of the empty block
    From posing tab I use the ARM sliders and move her arms all the up, add empty block, move her arms all the way down.
    When I click play her arms go up and down. This is the way I want it.
    At the end of the timelime i add another empty block and this time i move her legs up.. MY PROBLEM is that her Arms and legs go up at the same time. I want her arms to go up then her legs to go up.
    I attached a screenshot that might help. The arrow in the screenshot starts at the first frame. Can i make this arrow say start at 4 seconds?
    Thanks
    660 x 191 - 20K
    merged threads.
  • Block 1 - Arms Up
    Block 2 - Legs up
    I want the arms to go up then I want the legs to go up.
    I do not want them to both start at the first frame.
    Now when I click play the arms and legs go up at the same time.
    How can I make it where there go up 1 at time... Like arms up then legs up. Not at the same time.
    802 x 280 - 36K
  • Need help with timing.
    Any timeline software I have ever used plays things in order that they appear on the timeline. With DAZ everything starts playing at the first frame.
    From my screenshot I would only want the animation block to play when it is there time. When the playhead is over it.
    How can I make the timeline work like a real timeline? Now when I click play at the first frame all animations start. I do not want this to happen. I only want the animation to happen at the time I set.
    See Screenshot
    996 x 282 - 37K
    I can't help you with animations, as I usually only do still renders, but...
    Suggestion: Move the thread over to Commons or to DAZ STudio section, as the people who do a lot of animation don't usually frequent the New User segment of the forum.
    See Screenshot
    996 x 282 - 29K
  • How can I start different animations at different times?
    Block 1 Arms UP
    Block 2 Legs Up
    When I hit play the Arms and legs go up at the same time.
    I want the Arms to go up, Then I want the legs to go up. NOT BOTH AT THE SAME
    Block 1 Arms UP
    Block 2 Legs Up
  • We merged all threads as they were covering the same topic.
  • It looks like you attempted to post your new threads to The Commons. If you would like the thread moved, please ask and we can do that for you.
  • This seems like such an easy question. It was reccommended above that I ask this question in commons....
    I am going to delete this and ask in commons. This is crazy that ever single post be approved.
  • Since no one has been able to help I think you may need to open a Technical Support ticket. You can, if you wish, move the thread to the Commons by editing the first post.
