Some probs when installing DAZ 4.6
Hera
Hello!
I've installed DAZ 4.6 and it works just great! But then I have a problem with one of the side programmes.
It's the DS3 TextureAtlas 1.0.1.4 Win64. Here the installation starts, but then it stops with the error message;
There has been an error
The intstallation parh for DAZ Studio could not be found. "Texture Atlas
DS3 (64bit)" cannot be installed. Setup will now quit.
The application will exit now.
So how do I fix this?
Post edited by Hera on
Just go to My Account > Product Library, and type in Decimator, the plugin has not been updated for 4.6, so it will work OK.
Where is your DS3 64 bit installed to? The installer cannot find it by the looks of things.
DS4 has Texture Atlas built in -- you only need to install it if you use DS3.
Thanks both of you - I found a working set of decimator on my computer desktop, so that problem is solved. Will check texture atlas as well.
