About grass land products
I'm always trying to find a good grass product for DAZ, but it's kind hard. I want real grass, not shaders. I've found some pictures in some products which has really nice grass in it, like these
I wonder if anyone can tell me where are these grass from? I will be really appreciative! And if it's possible, I also like to know where the land base from in the last picture.
P.S. I've tried "Realistic Grass Evolution" before, but it doesn't look as good as these.
Post edited by Chohole on
..there is this:
https://www.daz3d.com/grassy-grounds-megapack
Works in both 3DL and Iray and can be applied to an uneven surface. However as it is geometry it will add to the render load.
This one is great: https://www.daz3d.com/realistic-grass-evolution (3Delight and Iray)
Here's an Iray render I did:
(ps: the Realistic Grass, here, merges with Iray Worlds' grass, in the background, just before the treeline.)
Thanks! I had used this one in Poser, I just start to get rid of Poser and change to DAZ, I forget this one.
But I don't know how to apply the grass on certian surface, I can only load one small piece of grass at a time, and the grass can only match a flat surface.
I've tried this, but I didin't render it so well like yours! Your work is great :) I seems can't find the right Iray light for it.
I wonder what background are you use in it? it matches really well.
The background (and lighting) is https://www.daz3d.com/iray-worlds-skydome which I use a LOT
It comes with plenty of variations. However, I may have added a little help from https://www.daz3d.com/treescapes-backdrops , but I can't remember.
I use this one almost exclusively. It's super light and realistic
https://www.daz3d.com/g3d-da-grass-and-plant-pack
Wow! This product is great! Thanks a lot :D
Although if the grass can be loaded on a uneven terrain will be even better lol
thanks a pretty scene
Since you will have to use instancing for any large area, Ultrascatter https://www.daz3d.com/ultrascatter-advanced-instancing-for-daz-studio allows for placement on uneven terrain.
Well that's just typical; looking for grass myself, and then discover I own this.
And that would be a "me too!"
