Cant Load Morph INJ/REM for Genesis 3 Female
Hello guys. i Have Problem .
I Have Komputer and normaly use daz and load my Genesis 3 Female and INJ/REM Body or Head Product. it work normaly and can morph my genesis...
The Problem is.
I install Daz n differrent Computer and Load my G3F . unfortunatelly the Problem is I Cant Inject Morph Body/HEAD from the Product. (Skin,Nail,Make up etc Work fine only Body and Head didnt Work) . INJ/REM is show on edit tab if succes but dont work on my genesis 3 .i already click on scene/parameter fo G3F. i dont know what happening here, did i miss something?
I try several method like Instaling/Uninstal,from DIM or Manual Instal,delete my folder, Reset My database on Daz, replace my file asset etc... but still didnt work
sorry for bad english. Thanks For Help
Genesis does use Inj/Rem poses as such - the files that are labelled are probably just settings (what used to be labelled Mor poses, for Morph). It sounds as if they are using morph sets which you don't have isntalled on the other machine - the product page for the character, if it's from a store, should list the packs used.
