virtual penny 4 yor carrara thoughts ?
15354555759
    forgot what i was workin on >.<
    flu-zees zapped me >.<
    hair combs, normals
    softbody jiggle
    is it time for valentines renders yet? or wait for after superbowl?
    so when you lay out a line, add thickness, the original line remains?
    adding thickness doesnt just puff it outwards, is puffing inwards as well?
    twould be interesting to see the effect of ior through a plane, vs a cube, vs reversed normals
    i better go sleepy, >.< work in the morning.
    so many questions!! like the look of shadows falling on an object with subsurface scattering
  • HeadwaxHeadwax Posts: 10,434
    I have no idea what you are talking about but it;s always pleasnt to guess.
    It's like 3d Haiku.
    I like the idea of shadows falling on subsurface scattering - the question being whether the shadows subsurfaces
    Mistara said:
  • PhilWPhilW Posts: 5,162
    Shadows aren't really a thing in themselves, they are the absence of light (at least compared to the "lit" areas). Usually not the total absence of light though, there will be environmental light giving color and definition into the shadowed areas.
    You can add thickness with both positive and negative values to create a new surface either inside or outside the existing object. I'm not sure how this would work with just a line and no polys though - just try it and see!
    edited February 2018
    attenuation is only on lights, nothing to do with shadows?
    inverse squared, linear, etc  up side down
    Post edited by Mistara on
  • VyusurVyusur Posts: 2,235
    If you want to get soft shadows with the default render engine, on the panel "effects" turn on the box "enable soft shadows" and encrease the size to a realy big value. Use raytrace shadows for smoother shadow surface. Don't use map shadows, they cause artifacts and pixelation.
    278 x 262 - 20K
    Post edited by Vyusur on
    ty!
    what is shadow bias?
    never understood it
    My pleasure! You don't need to touch "bias", leave it as is. Otherwise, you may get a fan-like shadow.
    tryin to figure out how to manually cut a 'tramp stamp' to fit,
    cutting vertically down the middle wont work, seams are more like a coast line
    the tc2 does have a tattoo option, but not for g3
    song so pretty in french
    dunno what language this. is, pretty
  • StezzaStezza Posts: 8,811
    thought I'd have a go at modeling some LiS style clothes for my actors that will be in the Chariot and Space Pod..
    started off real good and was just about to save when Carrara was hit by the big freeze....
    The song is pretty cool. But when I see 3d people among the real ones I feel the uncanny valley.
    song is from the Witcher 3 game.  Geralt and Zoltan watching Priscilla's performance.
    i'm in the middle of the Priscilla quest.  2nd try, messed up finding the villain 1st time.
    having another go at a G8F preset, starting over.
    wondering if it would make a difference to use ds utilities with my old pc with ds 4.8.  can't hurt to try.
    ... well, that didn't help fix it
    cant see the uderlying problem with g8f's nailbeds.
    cant think of how to isolate 1 toe for corrective morph?
    thinkin separate x,z,y morphs to move those misbehaving g8f nailbeds to where they belong.
    heavy sigh, thinkin is time to write off g8f as the worstly made toenails ever
    worse case of 3d tinia eva!
    wondering why the image thumbnail doesnt show uploaded when creating a post.... but appears when you post....
    someone been playing with forum code maybe!
    never noticed before cool
    mebbe is my method?
    befor i hit post comment, i right click on the upl thumbnail, oprn to new tab. i manually edit the url to take out /thumnail part,
    then insert image with twekaed url,
    then hit post comment
    how do yoos do it?
    Mistara said:
    it's no longer showing the thumbnail for me in edit, when I attach a file it says it uploads but nothing shows... maybe a chrome thing.... yet the image thumbnail is posted when I post...
    Post edited by Stezza on
    it's just blank!!
    but they will show when I post...
    875 x 619 - 319K
    737 x 518 - 41K
    Stezza said:
    i'm in chome, older version. my netbook winXP.  havent tarted up the win10 netbook yet
    8 cores on her way laughlaugh
    Saturday, February 10  1:17 AM  Package has left the carrier facility Redmond, WA US 12:37 AM
    i;se scared they sent an openbox, or previously returned item.
    my new rig should handle octane, i hope.  win10 big wildcard software wise
    tee hee
    rootbeer  rootme
    cores
    hope it don't get tossed around!
    exciting stuff ... new toys yes
    rootbeer   inconsistancies of content
    the pose presets work on incantoo skeleton
    pose presets do not work on the sy thingees
    g8m fbms work dandy on g8m and all his toes
    did they do the new toe thingies to him, or they skipped doing it to him
    !! enlightened
    a mermaid tail character would solve the toenail problem, lol
  • Stezza said:
    it's just blank!!
    Same problem  Just started happening around 4:00 PM Daz time.  It isn't your browser.  I'm using Firefox.
    Mistara said:
    !! enlightened
    I know that the guy doing a script to convert between different characters is also having issues with the nail beds.
    PhilW said:
    Mistara said:
    !! enlightened
    there's nothing that makes sense for a morph to move verts in 1 software and not another.
    the most likely suspect, thought something with the subdivision level, hypothetical verts.
    doesn't seem to make a difference.
