Daz mode, or glitch?
I cant get rid of this thing. I don't know what I did, or how to disable it. If this is a mode then I just need to know how to disable it.
If this is a glitch or something I need to know how to fix this. Thanks
Post edited by Angel on
You need to go to Window > Tabs > Tool Settings, and change During Manipulation - DrawStyle to Use Current (Off).
You can also just post images on the forum here by using the Browse button just above where you write your post.
Window > Panes > Tool Settings
Under "During Manipulation" set Draw Style to "Use Current (Off)"
I do not know it is same as your case.
but as for me,, when I load saved scene, in new beta daz studio,
and zero poze, or pozing figure,, about some scene,,
the mesh often break in 3d view only,as like your pic.
then I checked many times,, and find,,
I need to set SubDivision Delayed (off) to Persist (on),
before tweaking figure.after load these scene. (pic 1)
if I do not change the option,, and move rig,, or zero pose
about which I saved before in current product version, often break, and I can not correct it.
(pic 2)
but if I change setting to Persistent (on) , after load the scene,,
I can move rig or zero poze,
then return setting to Delayed (off), there is no problem.
it is so wired,, because,, I can not say,,it happen every times with the option..
but I can re-make the break sceane.
https://bugs.daz3d.com/view.php?id=50341
I find answer ^^;
as for me,,, I need to change Display optimization,, best to better ,,
if I change better,, the broken 3d view re-made,,, .and how I set the subD,or skinbinding,
the problem do not happen about the same scene.
it seems my,,AMD graphic card problem?!
why,,,why I can not use,," best" ,,,
I am so shock ,,I want to cry,,,.
then now I find,, I miss the place to reply,, these problem is not concern about this topic,
so sorry ><; I opend many pages at same time,, so I missed .</p>
Thanks for the help guys. your great.
